aussie_boy
Sep 29 2008, 05:09 PM
hello guy's
got myself a Patrol about 7 months ago. until just recently i started to modify it for off road and rock crawling
ive got a Patrol GU 4.2 ltr turbo diesel
so far ive done the following mods:
-new tuffdog srings and suspension
-mickey thompson baja ATZ (tires)
-IPF spot lights
-safari air scoop
-cargo barrier
-new rims to fit the mickey t's but forgot what brand
-new oil and temp guages
-dual battery system
thinking of putting an intercooler in it but need the money to it with
any of you guy's have any suggestions please write them down
[attachmentid=592807]oh yer fogot the photo
Drunkman
Oct 12 2008, 01:34 AM
very simple my friend if you want to use it for rock crawling you would need some huge soft high profile tyres which would cost you say about at least $900 each for the tyres. and you would deffenetly need an intercooler beacuse with rock crawling your doing high revs and no speed so your engine wil heat up very very quikly specialy being a turbo. just put it this way the modifications to a car like that would be endless all depending on how much you want to spend. from past experince man 4WD's are ****ED they need alot of money. engine on my explora blew up twice. it was an off road one too.
aussie_boy
Oct 14 2008, 07:03 PM
money i have.....and these hi profile soft tires? can you give me any info on them? and why did you get an explora? only 4WD i would trust are the landcruisers and patrols and sometimes the navaras and mazda BT-50
Drunkman
Oct 15 2008, 11:30 PM
Man my explora was good i did have a bit of a work done to it. i use to go 4WDing with a few mates they had landcruisers and i use to kill them landcruisers, Speed, sand downs and the whole lot. the only problem was i needed serviceing twice as much and use to go through fuell like crazy. first time i blew it up i was doing a burn out in the sand the diff layed in the sand locked the gearbox and blew the engine, second time didn't service it for a long time then it just decided to blow up and i just couldn't be stuffed and more. and the tiers i'll find the sit and send it to you next time im on. they are special rock climbing tires expencive things but its worth it if your into 4WDing.
