Full Version: Audio Problems
dogstar7151
well here is the problem i have a pioneer DEH-2950MP head unit, now my problem is when i turn my ignition on the head unit turns on, the amp turns on and when my CD starts up the only sound is coming from my subs not the speakers, ive had this problem b4 and i still dont no how i fixed it and i dont no how to reset my head unit either and ive looked in google. so if anyone could help thanks a bunch
warney
Just started ? You just install the unit ? RCA's plugged in the right channel ?
dogstar7151
ive had it instaled for about 10 months and ive checked all the plugs and even disconected everything adn still only from the subs
Audio Express
set the rear output on it to full range. by default it is set to sub out.
dogstar7151
ok then and how would i do that on my head unit??
Audio Express
got the book for it?
dogstar7151
yeah ive got the book for it, but i cant find how to do it
warney
QUOTE(Audio Express @ Sep 22 2008, 09:45 PM) [snapback]1282910659[/snapback]
But it just started ????
Audio Express
if he was fiddling with settings that would explain it.
Rookie ROX
For Pioneer - Turn the headunit off, then press and hold the Function key (I think it's Function) and it will turn on into the Settings mode - Keep pressing Function to scroll through the options, there should be a setting for the Preouts where you can change between Sub and Full Range.
ROCK ON
R~R
