Full Version: Manual Conversion
wolf91
hey guys im interested in starting a project on a cheap s13 over the next year or so and just wanted to know if i was to get a cheap auto how much itll set me back to get a manual conversion?
thanks for your time
w13c
might cost you around 500 for parts, gearbox, crossmember? clutch , pedals, master n slave cylinders, maybe ecu?..generally it will be cheaper to sell the car and buy a manual... have a search for more info,
edit: try search more in the future cause most likley some fellow boost loosers will flame you for asking such simple questions.
tim_koelma
^^ +1
And it will depend how much of it you can do for yourself. My guess would be... if you don't know how much this sort of thing would cost, then you probably don't have the expertise to try a DIY job so labour is going to cost you.
That's not a piss-take but I wouldn't want you spending your hard-earned on something you could have done cheaper if you started out with a manual.
It will also depend on what you want to do to the shifter / clutch / gear box / etc once you have it and how much you're going to spend on the bits you put in. If you're going to spend up big on expensive parts then it might make very little difference: you could pick an auto or manual and either way you'll spend $$.
But going from stock auto to nearly-stock manual might cost more than it's worth.
wolf91
thanks for your help
tango
your looking around the $1500 mark suplied and fitted with a second hand clutch.
kurly_ni5m0
I second that, around $1500 supplied and fitted.
If you can supply all the parts yourself its around $700 - $800 for fitting.
I just had my conversion done, cost me around $2,300 as I got a custom 1pc tailshaft and a custom clutch setup.
I found Universal driveshafts the best place for the tailshaft and direct clutch for the clutch / flywheel.
DET20
Why so expensive?
Clutch pedal - 50
New master and slave - 80
Box - 200 (CA) 400 (SR)
Tailshaft - 100
Clutch - 300
Flywheel - 50
Crossmember - 50
Its only a few hours work to do the conversion as well.
You and a few mates with a trolly jack and stands would be able to knock it over in a weekend even if you dont know which end the the tailshaft goes smile.gif
Budget 100 for beer!
S13's are the perfect example where the bandwagon (awww just buy it already done) doesnt apply, despite what the trolls say on here.
70XIN
Mr X
QUOTE(DET20 @ Sep 18 2008, 10:32 PM) [snapback]1282895472[/snapback]
Why so expensive?
Clutch pedal - 50
Tailshaft - 100
Clutch - 300
Crossmember - 50
the lazy generation..
i'm sure there would be a walk through on the net.
DET20
Dam straight there is a walk thru.
Nissan silvia dot com
turbomarch
Why so expensive?
Clutch pedal - 50
Tailshaft - 100
Clutch - 300
Crossmember - 50
where can i get a sr box for $400?
70XIN
forums, friendly wreckers
Timmyp34
Why so expensive?
Clutch pedal - 50
Tailshaft - 100
Clutch - 300
Crossmember - 50
Thats a cheap SR gear box. i would also get a heavy duty clutch while your there
DET20
Just look around, i brought mine for 300, only fools goto the usual known "workshops and pay 600 + for a standard s13 / 14 box.
QUOTE(Timmyp34 @ Sep 18 2008, 11:00 PM) [snapback]1282895592[/snapback]
I brought a second hand clutch and flywheel from asian auto spares for 150, was a 5 puk brass button and it was hell fun!
tango
Why so expensive?
Clutch pedal - 50
Tailshaft - 100
Clutch - 300
Flywheel - 50
Crossmember - 50
why so expensive.
if you do it under your parents house it would be cheaper but when you have a workshop to run with all the aditional overheads it is going to cost more.
besides your not far off on your quote, just add some labour costs and brake fluid cost and gear oil cost and your nearly up to $1500.
sorry i can't spell tonight i'm too tired
