In WA, what exactly is required for legal shaved doors? I'm guessing an engineers cert. is required too.
As for running a car over the pits, its it like over east where you even sometimes need a permit to have larger rims on your car?
Thanks
Nick
Sep 11 2008, 09:07 AM
I am not 100% surewhat is needed to legalise shaved doors but yes they will need to be certified by an engineer.
There is a certain size you are allowed on a car without requiring a permit, this can be found on the DPI website I am sure.
yahooHJ
Sep 19 2008, 05:38 PM
not sure about the shaved doors but as for rims in WA u can only go 2 sizes bigger than what ur stock size on ur car but if i was you id put stockies on just saves the hassles
The 2 sizes larger is just an estimation, that is not actually the legislation. There is a ruling that it must not vary from the original total diameter by x%. And there is a sizing chart available through the Depart of Planning and Infastructure.
coolneasy69
Sep 22 2008, 08:26 PM
It use to be that you could only 1'' bigger than the largest factory fitted tyre on the car. So if you ran 14*6'' you could only go to 15*7's. DPI has a list of all mod's that don't need to be engineered. All Mod's to the body that change it in a stuctural manner need to have a engineer sign off on it.
