Full Version: My New Toy
Boostcruising.com > Drag and Track Racing > Drag & Track Racing Disccusion
14MYL
just thought i would throw up some pics of my new pig.
She has a pretty much stock bottom end in her at the moment but have a stroker kit on the way. Just have to make sure I dont break 11s as dont want to go out of bracket currently runs a 12.4 so hoping stroker will bring it down to mid 11s then a small shot of nos or avgas should get me where I need to be.
Full Tube chassis
308 30thou L34 heads, Roller Rockers, 282 Crower solid cam, Crane solid lifters, Rollmaster timing chain, Edlebrock performer inlet with 750 Mighty Demon, TPP Bug Catcher, Holley black fuel pump, 18 Litre alloy fuel tank, Turbo 350 with 5000 stallie, Procomp dizzy with MSD6, New Alloy Radiator, New Tailshaft, Tubbed with 28x10x15 Hoosiers, Plus New set 26x10x15 MT’s, Front Runners, 9” 4:11 Richmond gears with 28 spline billet axles, Roll cage, Pro shift stick.
[attachmentid=576778][attachmentid=576782][attachmentid=576784]
532MAN
Looks really nice.
The only thing i would be worried about is the Procomp dizzy. If you can afford it, replace it as soon as possible. I was using 1 as a replacement while my dizzy was getting rebuilt and i broke the oil pump drive split pin and rotor button broke once. I used it for about a week then parked the car up until mine came back.
I have heard so many horror stories about Procomp shit breaking. Its just not worth it IMO.
14MYL
yes going to change that. It goes into the shop on wednesday for a strip down and tickle up of bottom end as it is pretty standard and needs better compression as standard pistons still in it.
532MAN
QUOTE(14MYL @ Sep 7 2008, 09:58 AM) [snapback]1282841777[/snapback]
Mill the heads a little will give you some more compression.
14MYL
Few more pics of her
[attachmentid=580799][attachmentid=580800][attachmentid=580801]
would love to keep compression where it is and throw a 671 on her but dont want to throw to much money at her.
14MYL
Well I have decided to go for a whole new heart transplant so out with the holden and in goes a chev. just finalising all the small crap like sump, remote oil filter smaller starter and reweld radiator
532MAN
Small block? Big block? Stroker? Trans staying the same?
14MYL
QUOTE(532MAN @ Sep 30 2008, 09:53 PM) [snapback]1282945264[/snapback]
just sitting with 350 for now going to lower stally when I can find one to buy and sticking with th350 as cheap when destroyed. see what times it pulls then will work out if to go to 383.
Has sponsors now so they will be helping with build price. hopefully will be at tnt at willowbank in about 3 weeks for final tune, but you know what its like. problem after problem with conversions and tech inspections. so far motor is apparently at 435hp with mid 550squares of torque. But will see when she hits the strip. Figures are nothing, times are everything.
532MAN
Torque seems a bit high compared to HP unless it made the power at very low RPM.
Any idea on the weight of the car with driver?
14MYL
bonnet and scoop are on just waiting to see engine height then may chop scoop down
[attachmentid=633970]
[attachmentid=633971]
mikejoel
This looks really cool. I had been meaning to do some improvements on my own car but we'll see. I am still waiting for inspiration on how best to go about it.
14MYL
have just bought some weld warriors to go on it as it has shitty kidney beans on it and have to go.
also has msd pro billet dissy now and belt driven, dropped the stallie down to a 3000 for now. just chasing some headers for it and she is ready for the strip.
TUF120
chris davey
Nice car. Only thing is seems like it is way hardcore for S/ST! Tube chassis!? Why not charge it or something and run SS/AA?
14MYL
The old problem of $$$$ for now. But hopefully in the future.
pvk308
Plenty of potential in this car definately good move going the chev. I'm not sure on the stall choice what numbers are you hoping to run. I personally would like to see that converter up around 5000, ahve you gone lower due to engine output what diff gears has the 9 in got nice starting point
14MYL
QUOTE(pvk308 @ Feb 25 2009, 08:03 AM) [snapback]1283637227[/snapback]
4.11 richmond 9 inch. Was thinking that it wont rev as high and not runnin solids so was going to drop the stall down. but have decided to stick with the 5000 that I have and then throw some solids and super victor on later.
14MYL
350 Chev small block. Bored 30 thou, Arp bolts through out, Hi vol oil pump, Forged Keith Black Flat top pistons, Edelbrock Performer dual plane intake, 750 mighty deamon carb, Moly Rings Reco double hump fuellie heads ported with Stanless steel oversized valves, BRC Roller rockers, Rocker girdles, Comp cam 274, Hardened pushrods, king competition Bearings, Holley black fuel pump, SSI flex, 3000 stall, Gilmer Belt drive, Rollmaster dual timing chain, MSD 6al with 2 stage rev limiter, MSD pro comp dissy, super street custom hi vol oil pan,10 - 1 Compression runs on AVGAS.
[attachmentid=709893]
the new billet ceterline warrior rims 10" rear 3 "fronts
[attachmentid=709894]
[attachmentid=709895]
[attachmentid=709896]
QUOTE(14MYL @ Mar 8 2009, 01:39 PM) [snapback]1283697340[/snapback]
I like! A huge blower on the manifold would top it off, or even a pair of big snails hanging off the manifold tongue.gif High comp forced induction? YES PLEASE!
yoshi1000
Fuggin awesome!!! Can i be a rude prick and ask what soughta coin that chev has cost to get it where it is ?? I'd love to do somthing like that but the $$$ keep scaring me away....
Si
14MYL
QUOTE(yoshi1000 @ Mar 13 2009, 07:56 PM) [snapback]1283732423[/snapback]
Si
Because it is a straight drag car I have not had to spend the $$$ on getting a street legal conversion kit but so far have spent about 10G on her. motor itself is probably around the 5G mark but dont really want to add it up as will only be depressing. at the end of the day everyone spends thier money on somethin. May aswell be on a chev. at this stage I think I am only about $500 away from finish line but am still unsure if I should go to a powerglide. Head says yes but heart say ""just get it on the track ffs" worry bout the problems later. been at the mechanics for bout 6 months now and bout time it had some time slips and addrenalin to show where my coin is going.
Have also bitten the bullet and decided to stick with the 5000 stall converter and will just sell the 3000 stally
QUOTE(532MAN @ Oct 1 2008, 09:36 PM) [snapback]1282949896[/snapback]
has had 300 kg stripped from her and weigh 89 kilo so should be light enough
pvk308
looks good so far mate good idea sticking with the 5000 converter the dual plane will have to go though and the super victor used to get some good numbers keep us posted mate
14MYL
QUOTE(pvk308 @ Apr 26 2009, 05:18 PM) [snapback]1283965061[/snapback]
yes I want to get rid of the dual aswell but am interested to see what the difference it will make so am going to run the dual then run Super victor. Will keep you posted. Only new update is that we have customised the panhard rod and gone to an adjustable 1 piece as looking at old set up it was not pointing straight. Have also purchased some engine mounts to suit commodore to chev from castlemain rod shop as got them on the cheap plus steering colum spacer to suit.
pvk308
mate would love to see some pics of the new rear suspsensiuon set up sounds like the goods if you dont mind
14MYL
after alot of hassles the new heavy duty adjustable pan hard rod is finally welded in an now has no side movement
14MYL
is now just getting paint cut back and car stickered up then put the motor in and check for measurements for headers. Is now going to be super sedan 8 - 10 second bracket
PIG208
Thats an awesome project matey thumbsup.gif can't wait to see it turn tyres in anger @ the track
14MYL
QUOTE (PIG208 @ Aug 25 2009, 07:53 PM) *
I cant wait either. Is a slow process but not far off soon
CAM-327
heyy man nice progress, any updates on her at the moment, dying to see how this has turned out thumbsup.gif
14MYL
QUOTE (CAM-327 @ Oct 10 2009, 11:24 PM) *
Well its just hit its 1 year anniversary in the shop and have not had much further progress as racing doesnt start back up till Jan and been to busy at work to get anything else done. might have finally found some headers but they suit 18 degree heads so just trying to look into if i can get some spacers to match them up. Hit another stumbling block of starter needing to be put on the other side so looking into this fabrication as well. Is hard work but will be worth it I reckon. fkn better be. not giving up. have sold the boat now so no coin problem just fabrication problems.
CAM-327
ahh thats good to hear uv got the money do finish it, i see soo many projects so close to completion and then they either cant be bothered and sell it or just rush it and blow something up on the track. love your progress, keep us all posted thumbsup.gif
rydnlw
nice work... love the car
CAM-327
just a quick question.. you wheels.. the welds..
what dimensions are they. and may i ask.. how much did they set you back
thanks bud
