Full Version: Garrett Gt42 Set Up
Boostcruising.com > Drag and Track Racing > Drag & Track Racing Disccusion
boostnbt1
hey guys i was looking at buying a gt42 garrett and a want it to run right in my rb30et there is lots of different sizes in the compresser wheels and everything but im confused on what to get. i want it to spool up at 3000rpm and come on hard.
any sudjestions on what set up i should get
cheerz
Richie$$$rich
A GT42r will not be on boost at 3000rpm. even on a rb30et. Depends on what trans you are running. Give you an idea. I run a 26/30 behind a powerglide. with a GT42r. its on full boost at 5200rpm.
slo32
bout the same as ritchie boost around 5000rpm id go a to4z for more response
IEATU
hmm, but when that 42r is on song, it would be a sight to see. I just hope your internals can handle what a gt42r has to offer you. If your not willing to see the potential of these turbos I wouldnt bother getting one as they are turbo that likes the high boost 20-30+ psi
SLOW6
I have a 42R on my VL with .96 exh side... comes on boost around 4800rpm and comes on hard... my suggestion to you is a 35/40.. they seem to do the trick as the 'all rounder' 42 is a lag monster but great fun smile.gif
SHERIF
mines on full song lot quicker than 5000rpm
NOSRX3
i HAVE A GT42 IN TURBOS FOR SALE?????
i HAVE BEEN INFORMED ON BOOST BY 5000 ON 13B. wOULD BE ABOUT SAME FOR RB.
GOOD LUCK WITH YOUR PROJECT.
Koe
the only way I see to loose lack is to get a auto tranny and modify it
MRT66
get a 6boost turbo manifold and you will get urself the quickest response with that size turbo
IGNITE
With my GT42 I'm on boost under 5000. Get Gas if you want to run a 42 & make it come on quick.
qv123
yeah depends what manifold you stick it on. 42rs on xr6 turbos are at full boost at 3500 if setup correctly but they are a much bigger engine. imo that size is way to big for that size engine unless its bombed
