Full Version: Mazda 929
Andi_grace
hay i have a mazda 929 2l 4cyl rwd 5speed i was wondering how to get it more drift able it has irs so i was wondering if i could lock it up and other stuf i can do to keep it safe but more drift able cheers
99v8Lux
Andi_grace
please dont post if you just being a tool i know its not the best car but im only looking for a bit of help
Timmyp34
if its not a daily driven car.
weld the diff strip everything out inpart from the dash and front seats
chop the springs or take them out hell you could even weld the springs stifff.
cut the exhust of atfer the headers
MFC05
QUOTE(99v8Lux @ Jul 26 2008, 01:50 PM) [snapback]1282656844[/snapback]
Mr_Sleepy
what model? alot of Rx7 stuff like coil overs, brakes, diff and other suspension goodies are interchangeable. which means you dont need much custom stuff and most of the bits you will need are available off the shelf.
there actually a pretty good chassis for drift, its just uncharted waters..
If i had one (again) i would put an sr20 in it (good aftermarket support), change to a s4 rx7 diff with osgiken center, put s4 rx7 aftermarket coils in it, fit s2 rx7 whiteline swaybar in the front and also fit an aftermarket fuel tank as the factory one is a bastard for drifting (trust me, personal experience).
heres a pic of me having some fun in my old one (private property), it was totally stock..
Andi_grace
i was thinking more of a rb20 or a commodor v6 as i mesured it up and it seem like it will fit and i can get away with it for under 1000 driveing
bsears
DUDE ive got a 6cyl 2.0l turbo LUCE (929) for sale , is got electronically adjustable suspention an lsd $1500 if u want the car - 0447162845,-bj
LordNafe
If you cang et some early model rx7 coilovers to fit, do that. Coilovers and welded diff will be a very good start.
It will be able to drift with a stock motor with diff and suspension done. You'll just need to enter the corners a bit faster tongue.gif
The rb20 and commo motor might be cheap, but they are also heavy. Just cause it fits, doesn't mean it's good. The weight balance (particularly given the relatively short wheel base) will be terrible.
I think if you want a cheap motor, do a ca18det conversion. Cheap, much lighter and effective.
It may not be the "ideal" paltform, but you can sure as hell make it work!! The basics (suspension and diff) will be cheap too.
singo182
my mates got a 929 which he is turnong into a drift car and the engine that came out of it weighed a tonne hes no putting an rb30 in it and it dosnt sit no where as low as it use to with the old engine in it
CAM22T
If its powered by a FE 2.0, then i know of a bolt in motor that will match an SR20 for power and reliability.
What model of 929 do you have ?
