QUOTE(8r3n0 @ Jul 20 2008, 10:07 PM) [snapback]1282631788[/snapback]
if i make a cage is there rules on positioning of bars? any info will be appreciated. i want to make some to the proper standards. NOT HALF ASSED.
oh and also drop tanks too
size and any other requirements thanks
What state are you from, as each state has slightly different rules..
For Queensland Transport Approval
* Pipe size for roll cage can be made out of Chrome moly (unsure on steel grade category) Min 45mm diameter unsure on wall thickness sorry, or Mild steel min 51mm diameter and min 3mm wall ( I personaly use 4mm wall)
* For a 4 point cage (ONE MAIN BAR AND TWO REAR SUPPORT ARMS) Main center bar to be "legal" must have mounting plates min size 150x200mm to be welded into chassis and or floor pan. ( reccommend you see an engineer or boiler maker ect on where to weld ect you can just put the plate anywhere) Then the centre bar must be welded in to place making sure that pipe is a decent distance away from head in normal driving position, (i roughly work on approx 200mm away from head) Specs for rear cage arms if you will still be using the rear seats, the bends for the back window must not exceed 35 degress, after the bend the pipe must continue through the rear parcel tray to the boot floor with no more bends !!!!! (You will get the book thrown at you if you do !! ) *NOTE* I have seen people put plates on the rear arms at the parcel tray and drilled it to parcel tray and then made a second section to go from under parcel tray to boot floor. I dont know if doing hat is legal !!! ( Hope that made sense to you ! )
*6 point cages all door intrusin bars must be fully removable.
*6 point cages Front over bars must not intrude on drivers sight. ( I normaly sit in drivers seat and line them up with the door\roof pillars. Front over bars must not me in the "major driver impact area"
GENERAL
Welds must either be TIG welder or MIG ( With a QUALIFIED OPERATOR )
ALL BARS ON ROLL CAGE MUST BE PADDED (WOULD RECOMMEND PADDING ABOUT MIN 1 INCH WALL HI DENISITY WALL) Just remember if you in a serious akka a roll cage bar coming for your head is like a butter knife hitting an EGG !!!
Drop tanks no major specs just keep to your 100mm road clearence rule AND LOTS OF BAFFELS.. lol
If more info needed PM me
Hope it helps
