josh_d20
Jul 20 2008, 06:05 PM
hey guys just wondering what car i should put my motor in to
this is whats done to the motor if interested
ok the block is a rb30
rb26 head port polished
crower valves (3mm outlet) valve spring
crower cams (270 degrees inlet outlet) 11mm lift
crower cam gears
billet harmonic balancer adjusterble
billet forged crank
crower forged pistons, conrods, rings
blue printed, nitrided, honed rb30
block crack tested
twin hks 2835's pro series
hks head gasket
hks plenum chamber
custom turbo manifold
dry sump
petersons external oil pump
split fire coil packs
motec ecu
holinger 2 speed power glide.
15uzu
Jul 27 2008, 11:18 PM
Have a hunt around & see if you can pickup an old ex-Super Sedan Capri....should be an easy fit.
PIMPED_jzx100
Jul 31 2008, 09:10 PM
i would say either an s13 or for something really different put it in a ke70 corrola, good luck
josh_d20
Aug 19 2008, 06:05 PM
im thinking of puting it in a s12
HYBRID_AE86
Aug 23 2008, 12:03 AM
s12 would be the go with a decent diff.. silvia would have traction issues due to the IRS and the ke70 would twist the chassis. i suspect that the S12 would be an easier conversion, mounting wise. another possiblilty would be the 200ZX, or something along the lines of a 240z.
are you building the car to run on the street? i know of a fiat 124 unfinished tube chassis drag car (roller) that is cheap (he was considering 2J or 308tt to be fitted), something different anyway.
josh_d20
Aug 23 2008, 06:31 PM
yea it gonna have rego so yea
Richie$$$rich
Oct 9 2008, 01:11 PM
R32 GTR!!!
helrzr925
Oct 30 2008, 05:05 PM
datsun 1200
vomit
Nov 6 2008, 08:47 PM
Bogan vl!
ODD304
Nov 7 2008, 08:02 PM
dude, do u knwo chris that ownd a white tx3 with the bpt conversion
DarkAgent
Nov 8 2008, 12:14 AM
im gunna say an R31 pintara. bolt straight in .... put some pursuits on and a 9 inch diff.
get a beige one with rugs and louvre on back screen.
sleeper fun!
why did u build the engine with out knowing what car to use it with?
i have to ask. seems a little bit backwards!
GL anyways!
87f6xf
Nov 20 2008, 02:31 PM
hey mate got a r33 coup 3piece 18" drift rims, nismo spec lsd,kyb buzz spec coil overs 8settings {drift suspension},5spd twinplate brass button clutch good 4 1000hp,fiber glass bonet, motor is there in peices hks cams hks cam gears 800cfm nismo injectors 30/70 oil cooled water cooled kkr turbo big front mount,big brake upgrade ebc pads 0423462386 lookin 4 7ooo or open to swaps
sorry mate u allready looked at ay did the rolla get the re spray
josh_d20
Dec 8 2008, 10:53 PM
QUOTE(ODD304 @ Nov 7 2008, 08:02 PM) [snapback]1283120023[/snapback]
i dont know lol
QUOTE(1JZMX @ Nov 8 2008, 12:14 AM) [snapback]1283121022[/snapback]
sleeper fun!
GL anyways!
my brother built it originally for his vl then he gave it to me
spasm
Dec 23 2008, 08:35 AM
1000hp with those turbos?????? i dont think so.
[200]
Dec 24 2008, 05:58 PM
Bullshit you do.
Looking at the engine there would cost about 25k.
You must have worked some overtime at Maccas for a 16 year old to afford a motor like that.
But don't let the truth get in the way of your school yard buildup.
holinger 2 speed power glide - lol
01sik
Jan 1 2009, 07:49 PM
put it in a pintara wagon
QikRXTurbo
Aug 17 2009, 08:13 PM
If you have to ask, you don't deserve the engine.
geespec
Sep 24 2009, 12:23 PM
s13,s14 or s15
