Full Version: Dvd Backup Software
Damone
have a few dvds that are watched regulary, and are starting to show the signs of regular use...
wish to back them up for personal use..
have tried dvd shrink...
was wondering what other methods are available.
the red krawler
Rip them straight to an ISO? If its only for backup (or at least, ready to be burnt to another DVD) ISO will be fine.
Also media players like the Popcorn Hour (not to mention VLC and other PC software) play directly from ISO so theyre fine in place of AVI etc.
EDIT: Meant to add that DVDDecrypter will rip a copy protected DVD to an ISO for backup purposes.
Damone
size is a factor with alot of dvd's these days though...
which was where dvdshrink was handy. was able to rip straight to a 4.7g dvd.
^sims^
So DVDShrink worked but you wanna know other ideas too?
tonesy89
magic dvd copier u can download it but make sure u get a key gen with it
Damone
QUOTE(^sims^ @ Jun 8 2008, 07:41 PM) [snapback]1282444604[/snapback]
dvdshrink got an error.
Fuzzball
Apollo dvd?
Damone
QUOTE(Fuzzball @ Jun 9 2008, 08:02 PM) [snapback]1282449828[/snapback]
Apollo dvd?
ill give it a look.
Danzig
DVDDecrypter is good
John.
QUOTE(Damone @ Jun 8 2008, 06:41 PM) [snapback]1282444223[/snapback]
Just carry on using DVDShrink.
But get a program called DVD43, Which will hide any disc security whilst DVDShrink does its job.
If you want to do it easier, You could also acquire One Click DVD. That with DVD43 you can copy any DVD with only 1 click tongue.gif
Damone
mmmm
spits back the same error...
dvd shrink encountered an error and cannot continue
failed to read file "J:\"
Data error (cyclic redundancy check)
John.
QUOTE(Damone @ Jun 9 2008, 11:32 PM) [snapback]1282451051[/snapback]
mmmm
CRC errors occur due to a damaged disc usually.
Damone
dont think so in this case.
discs are fine.
managed to get anydvd though, and thats working.
Damone
oh, and those discs always causes dvd decryptor to fail too....
DB:57:SS
AnyDVD + Nero
zorba
I use shrink/ DVD Decrypter and always have. Works great for backing up all those dvd's that you watch all the time.
clawmech
The only apps you need are:
MagicISO / DaemonTools
AnyDVD
CloneDVD
Ive been using these apps for years and they always work. CloneDVD can take a dual-layer DVD and compress it to single layer (4.7gb) as it rips to either an image or burn direct to disc. MagicISO, Daemon Tools, hell even PowerISO, UltraISO etc all have virtual drive managers if you want to keep the movies in ISO format, then u can just mount ur movie image to the virtual drive and access it like it was actually in the drive
