Full Version: How To Remove A Fuel Tank
SUSPCT
Here is a quick Tech on how to remove a fuel tank in a HQ.
The removal was prompted by my need to sort the leaning out issue int he HQ under heavey acceleration etc...
The reasoning we came to is that the pickup for the HQ originally is at the fornt of the tank towards the top, sometime in the past my tank has been modifed to include a new pick up at the front but this still wasnt sufficient to flow the fuel my engine needs.
So i decided i need to weld a sump tot he rear of the tank and put twin pickups at the rear this should go some way to solving my issues of course a new or 2nd pump will help as well which will come for now is the removal of the tank...[/b]
This is the tank as it sat very dirty but other then that pretty standard looking fuel tank
First step was to Jack the car up to a safe working height we used a jack under the Diff and two axel stands either side of the diff.
Another pick of the tank from underneath before we start.
The tank needed to be drained of the 101 octane prior to removal we used an esky to catch the fuel
This pic shows the pickup that my car had been using this ISNT the factory pickup it was a modified one but it still wasnt doing the job this will be welded up when the tank sump is added.
The pickup fuel line will have to be removed to drain the fuel
The clamp has been loosened and the fuel line can now be pulled off.
This is what my current pick up looks like
Now the tank is drained its time to undo the 2 metal straps holding the tank in place we used an air compressor to undo the bolts as they were on tight.
Once the straps are undone the tank can be gentley lifted out of the car
This is what the under car looks liek with no fuel tank.
Here you can see the two straps that were holding the tank in place we had to cut the fuel sender wire to remove the tank i will re solder this when the tank goes back in.
You can see in this pic the fuel sender plug and wire and the ORIGINAL fuel pickup! how that ever flowed enuff fuel i'll never know!!!
The tank out on the ground read to remove the fuel sender
Removing the fuel sender is a matter of simply twisting it and pulling out
The fuel sender unit looks like this.
Another looks at where the tank usualy sits in this pic you can see my diff suspension and exhaust
This is the Tank completely out and drained of the last bit of fuel that was stuck in it
Another view of the pick up that was modified that still wasnt up to the task
JOB COMPLETE!
HUGE THANKS GOES OUT TO JOE! HE DID AN AWESOME JOB!!
Now the next step is to have a sump welded in and twin pick ups with -10 fittings welded on as well as a return line -6 fitting welded to the top near the sender plug.
The tank should look similar to this when done:
Nathan
Thanks for the write up.
jared_pulse
nice, u shud clean that tank up mate!! looks kinda dirty haha
good job tho
