Full Version: What Tacho Can I Get ?!?!
nickkyd10
yo ppllz
my car is charade, 1 litre 3 cylinder....
i want to geta tacho but for every one i find it says suitable for 4, 6 and 8 cylinder cars..
how do i find one that will be compatible with mine? or are these fine for me as well and its just that
the manufacturers dont bother writing this information down? lol
secondly would you recomend a big 5 inch one on such a small car or go for a nice little 3 3/4 inch one?
thanks
headsense
Your simply going to have to look for one that is compatible with 3 cylinder engines , it will most likely have dip swtich settings rather than a combination of wires that must be cut or joined typical of Autometer and the like . The problem is a three cylinder tacho will often require 1.5pulse per cycle ,this is not popular signal ratio for 2,4,6,8 cylinder cars but more so in gyrocopters and small aircraft engines .
Personally i'd source a tacho dash and be done with it , but if you insist check the VDO and Faria industrial instrument catalogues for compatible instruments maybe or you could run a flywheel pickup rather than an ignition pulse type instrument
Speco Thomas do a 2 5/8" 8000rpm 3 cylinder tacho kit refer Part No 250-03 white faced dial , silver bezel and fitting kit
nickkyd10
is there any 5 inch ones i can get?
Rookie ROX
Why? It'll look ridiculous and everyone will laugh at you. Don't give into the stupid rice craze.
ROCK ON
R~R
nickkyd10
lol ok well any 3 inch ones you no where i can get from?
pipster11
QUOTE(nickkyd10 @ Mar 3 2008, 08:37 PM) [snapback]1281999203[/snapback]
do what you want not what rookie wants you to do
i'd get an 8inch one just to piss him off
oh and put a fart cannon on it too
nickkyd10
yer i gota 3 inch dumper on it lol
Glynn.
ebay mate there should be a few for cheap
Dethra
Here's one...
http://www.crazysales.com.au/index.php?pro...p;postcode=4212
and here.... http://www.speco.com.au/tachos.html
right one at the top of the list.
