Full Version: Brake Stuff In Darwin
HASHIRIYA
putting new seal kits though my skyline calipers today.
and the kits didn't come with the rubber seals that seal the two halves of the caliper together
and just my luck i have lost one, its pretty much a 12.5mm od 2mm thick and 2 mm high square edge o-ring.
where would be a good place to find another one? winnile brakes? cbc?
SIKUNIT
Are you talking about the seals that join the caliper to the cradle on the slide pins??
Try cbc or phil kerr might also have some.
Rattler
QUOTE(SIKUNIT @ Feb 28 2008, 01:32 AM) [snapback]1281978632[/snapback]
HASHIRIYA
QUOTE(SIKUNIT @ Feb 28 2008, 12:02 AM) [snapback]1281978632[/snapback]
no when you unbolt the caliper as it is made up of two halfs
theres a two lil seals that for the fluid traveling to the other 2 pistons
will try phill kerr first
sp33d
Dude, they dont come with those O-Rings cause you arent supposed to seperate the halves. They have a very very high torque setting
Phil Kerr makes braided lines and shit, maybe he'll have the o-rings to suit.
I had to seperate some supra four potters (made by sumitomo) They are cast aluminium and cast iron on each side. I reused the o-rings without dramas. They are fine, provided they dont get wet and havent been exposed to the atmosphere for too long.
Being a 90' edge, repco should have them.
More importantly, when you have a look at the two sides of each caliper arounsd the area where the o-ring sits, make sure its dead flat, its kind of like head gasket style mating. Gotta be a spotless, almost machined finish.
I assume on your calipers, there is only one oil gallery that allows fluid through to the other side (so 2 orings in total yeah?)
C-Craft
Someone like CBC or Blackwoods will have O-Rings coming out of their ass
HASHIRIYA
QUOTE(sp33d @ Feb 28 2008, 11:13 AM) [snapback]1281979803[/snapback]
yes they are sumitomo
no they weren't tightly done up at all, I've put one back together done up to 35 ft pounds (i feel that is enough for them), yes i stoned both surfaces before assembly, bit of anti seize, obliviously someone had been there before. i took them apart sandblasted and painted them. just me being the tool i am i lost one. I'd go get one from cbc, but I'm not sure if its the same material cos if it isn't the fluid is just going to deteriorate it.
took them apart took all the fluid went solid and crystallized.
phill kerr make braids and stuff but doesn't generally supply so i guess my best bet would be winnillie brakes, then kerrys nissan provided i can put up with the mindas with the import cd in japanese and thinking he is 100% right like last time. no there is no such engine as a SR20DET only come out as SR20ET see look computer says I'm right...
[attachmentid=461855]
they look pretty flash to me now
[attachmentid=461856]
these should go good with them (black thing on paper is what i lost
[attachmentid=461857]
OUCH!!!
mz.mini
QUOTE(HASHIRIYA @ Feb 28 2008, 07:12 PM) [snapback]1281982421[/snapback]
OUCH!!!
Come on HASHIRIYA even I know that one is a aircraft engine bit wont fit your brakes thumbsup.gif
HASHIRIYA
JamieQ
Nice work they look alot better.
incubus
don't forget to let me know about them sr brakes and the inlet pipe for the turbo
HASHIRIYA
if its out atm I'll tax what you want off it tonight
sp33d
Are they Maltech braided lines?
HASHIRIYA
they be the ones. how can you tell?
sp33d
Maltech are awesome, I put them on all my cars, such a better feel from the pedal. Australian company and manufacturing to boot!
Any luck with the o-rings yet?
