gslrallysport
Jan 17 2008, 10:04 AM
GSL RallySport stocks the complete range of Koni Shock Absorbers!
KONI is recognised world-wide as a quality shock absorber specialist, focusing solely on high performing suspension-damping technology for cars, racing, specialty trucks, buses and trailers. KONI shock absorbers and ride systems are specifically designed for every application without any compromise to quality and durability. KONI utilise the best technology to fulfill the highest requirements for comfort, safety and vehicle (handling) performance.
KONI shocks include these exceptional performance features:
• Owner adjustable valving for wear compensation and owner ride quality choice.
• Adjustable over low and high speed damping ranges for overall smooth handling.
• 100% dynamometer tested for complete quality control.
• Many are serviceable.
For more information on which products are best suited to you application visit the
Koni Website or Contact Us!
andrew12a
Feb 12 2008, 06:35 PM
any prices on adjustables all round for a series 3 rx7? (sa22c)
cheers,
Andrew
gslrallysport
Feb 13 2008, 12:37 PM
QUOTE(regulator @ Feb 12 2008, 06:35 PM) [snapback]1281921011[/snapback]
cheers,
Andrew
Andrew,
Koni only specify the fronts, and they are the internally adjustable Koni Specials. $220 each.
There is a shock now that we can use for the rears, Koni Sports externally adjustable, but the car needs to be lowered at least 20mm as its a shorter shock. These are $150 each.
Regards,
Greg
andrew12a
Feb 16 2008, 01:08 PM
QUOTE(gslrallysport @ Feb 13 2008, 12:37 PM) [snapback]1281923378[/snapback]
Andrew,
Regards,
Greg
oh cheers mate, yeh im riding on superlows at the moment, with shocks that are only 20mm shorter than standard which is still too tall. i've only sorta been told that these are nice shocks, but dont know alot about them..
reguarding the front shocks which are internally adjustable, is that before they go into the strut or actually inside the bore of the shock? also does this have to be dont in the manufacturing process, or can I deciede to change my settings when I wish?
also, are these adjustable in height and re-boud aswell?
thanks for that,
Andrew
gslrallysport
Feb 18 2008, 01:23 PM
QUOTE(regulator @ Feb 16 2008, 01:08 PM) [snapback]1281934235[/snapback]
20mm shorter is all you'll get, and its because they're shocks for another application that they're shorter. For that car nobody makes shorter shocks for shorter springs.
Internally adjustable Koni's are adjusted by taking the shock out of the car, depressing the shaft all the way, then turning from left to right. You can change setting's when ever you want, you've just got to take them out of the car.
The adjustment is a combined Bump/Rebound... There's no adjustment for height. That would require a coil over type setup with a threaded tube or similar.
Regards,
Greg
Apr 10 2009, 06:11 PM
you guys still runnung?
im after some shocks for a Ra60 celica...
im planning to use sw20 rear shocks.. can u supply these?
how much for a pair ?
alfamale
Apr 12 2009, 09:37 AM
silly question that you might know the answer to
my alfa is running koni's all round standard, is an 82 model, my question is, can these shocks be ajusted, re-gassed or whatever???????
can they be rebuilt as such or do i just need to get some new stuff???
gslrallysport
Apr 14 2009, 02:19 PM
QUOTE(ecko @ Apr 10 2009, 06:11 PM) [snapback]1283882238[/snapback]
Hi mate,
A pair of externally adjustable Koni Yellow Sports to suit the rear of SW20 would set you back $585 delivered.
Regards,
Greg
QUOTE(alfamale @ Apr 12 2009, 09:37 AM) [snapback]1283888602[/snapback]
In a Koni I'd just be buying new, as relative to rebuilding (where available) won't be a whole lot cheaper than buying new. If it was Bilstein or DMS or something alone those lines I'd definitely look at rebuilding, but if the Koni's are flogged then best option will be to just buy new.
Protius
Apr 15 2009, 07:22 PM
How much for fronts and rears to suit an n13 pulsar.
gslrallysport
Apr 16 2009, 11:15 AM
QUOTE(Protius @ Apr 15 2009, 07:22 PM) [snapback]1283908760[/snapback]
Koni Red Special
Front $219 each
Koni Yellow Sports
Front $245 each
Rear $245 each
Regards,
Greg
sT(.)(.)k
Apr 21 2009, 04:08 PM
G'day Greg,
Do you guy's stock Koni 8212's at all?
gslrallysport
Apr 21 2009, 04:35 PM
Yep can do for sure. They're not cheap but!!!
Do you know which specific one you were after?
sT(.)(.)k
Apr 21 2009, 05:01 PM
Not sure sorry. Will call to get more info
Jay-Dee
Apr 23 2009, 03:52 PM
Front and rears for a ST162 celica?
gslrallysport
Apr 27 2009, 09:57 AM
Hi mate,
Koni sports yellows for the ST162 are $315 per shock front or rear.
Regards,
Greg
03accent
Sep 5 2009, 10:16 PM
how much for full set koni yellow sport strut inserts
for hyundai accent 03 1.6l
and r the rears externally adjustable on the car?
thks
ed
606gti
Sep 6 2009, 09:06 AM
can you pls pm a price for front and rear koni yellows for an 07 mkv vw golf gti
gslrallysport
Sep 8 2009, 09:48 AM
QUOTE (03accent @ Sep 5 2009, 10:16 PM)
thks
ed
Hi Ed,
Koni Yellows to suit your Accent are $289 each for the fronts, and $239 each for the rears. The rears, although they are a yellow sports, are only an 86 series shock, so aren't on car adjustable, need to be take out and compressed to adjust.
Regards,
Greg
gslrallysport
Sep 8 2009, 09:49 AM
QUOTE (606gti @ Sep 6 2009, 09:06 AM)
Hi mate,
Koni Yellow Sports to suit your Golf GTi are $379 each for the fronts, and $199 each for the rears.
Regards,
Greg
03accent
Sep 8 2009, 03:55 PM
QUOTE (gslrallysport @ Sep 8 2009, 09:48 AM)
Hi Ed,
Regards,
Greg
is that $289 for the front pairs?
and $239 " " rear "
total $528 full set
ed
biza
Sep 8 2009, 05:07 PM
read his reply again mate, each as in each shock
gslrallysport
Sep 9 2009, 08:32 AM
Correct, a full set of Koni Yellows would be $1056.
83_SUS
Sep 9 2009, 06:11 PM
all round for a VW golf mk4
gslrallysport
Sep 10 2009, 01:17 PM
Hi mate,
What model Mk4 have you got?
Regards,
Greg
83_SUS
Sep 11 2009, 02:30 PM
all mk4s shud be the same but its a 2.0L generation
gslrallysport
Sep 14 2009, 01:57 PM
QUOTE (83_SUS @ Sep 11 2009, 02:30 PM)
There's 4 different options on shocks to suit Mk4. Koni Yellow Sports to suit your car are $375 each for the front, and $205 each for the rears.
Regards,
Greg
2jz_calais
Oct 19 2009, 07:28 PM
how much for koni yellow sports to a suit a vl front and rear
hacks
Oct 19 2009, 08:55 PM
hey bud, whats available for a subaru liberty rs 1991(awd turbo model), just need front pair preferably coilover, thanks brendon
gslrallysport
Oct 20 2009, 12:49 PM
QUOTE (hacks @ Oct 19 2009, 08:55 PM)
Hi Brendon,
Our entry level coilover that we supply is DMS 40mm. For a front pair you're looking at $1595. That includes springs, freight and GST.
http://www.dmshocks.comAnything less than that and you are FAR better off getting a quality shock spring combo like Bilstein/Kings. Koni doesn't have anything available, but we can quote up on the Bilstein if you like.
Regards,
Greg
gslrallysport
Oct 20 2009, 12:51 PM
QUOTE (2jz_calais @ Oct 19 2009, 07:28 PM)
Hi mate,
Koni Yellows to suit VL are $310 each for the front, and $229 each for the rears.
Regards,
Greg
elltee
Oct 25 2009, 09:46 AM
koni yellow fronts for a 97 honda civic i got quote $190 each from my auto part dealer can you do better price?
gslrallysport
Oct 26 2009, 12:08 PM
No chance, your business is all theirs!
Regards,
Greg
littlefireyone
Oct 28 2009, 12:39 PM
How ya going,
I was looking for a price on adjustable Koni yellows to suit this monroe number - 25 3632 - Holden VB-VP commodore. They were inside a front set of cusco comp s's running with thier standard 7kg springs? anyway I want to use the bodies with 250-300lb springs in a 900kg Datto that sees monthly track duties and khanacrossing duties.
gslrallysport
Oct 28 2009, 04:24 PM
Hi mate,
Koni to suit is $319 each.
Regards,
Greg
eligh666
Oct 28 2009, 04:25 PM
hey mate after a price for some front and rears for my datto 720 ute.
LUXPSI
Oct 29 2009, 01:05 PM
Hey Greg,
I'm getting king springs ultra lows in my VE sedan and was just wondering what shocks you would recommend, to go with the springs?
Cheers.
gslrallysport
Oct 30 2009, 05:16 PM
QUOTE (eligh666 @ Oct 28 2009, 04:25 PM)
Hi mate,
Need to know if it's 2WD or 4WD, and also build date mm/yy?
Regards,
Greg
gslrallysport
Oct 30 2009, 05:27 PM
QUOTE (LUXPSI @ Oct 29 2009, 01:05 PM)
Hey Greg,
Cheers.
Hi mate,
The shock I would recommend would be Boge. Dedicated shortened shock for the VE, and $145 each for the front, and $84 each for the rear. Both in stock.
Regards,
Greg
