on_boost
Jan 13 2008, 10:38 PM
top mount give u more downlow torque which is good for cornering and you dont need to worry about heat sink on a track. Im assuming front mount would only be good for the straights but it could have the potential to cause air restriction to the radiator which could cause over heating on a prolonged use racing all day. Obviously an oil cooler would be good for prolonged racing
IEATU
Mar 14 2008, 06:29 PM
since no1 replyed, id say front mount, as when track racing your always thrashing it so your intercooler will get fairly hot fast, esp if its a small top mount. But it would also come down to how much power you are putting down.
hope that helps
bop001
Mar 14 2008, 08:42 PM
buy the latest ignition dvd. they did both and got better results with a fmic. but are u serious man? fmic is larger than a top mount. and gets most airflow.
seems blatently obvious.
+ the clutch fan sucks air, so u always get air thru the radiator.
tas corolla
Mar 30 2008, 01:52 PM
as long as you dont go a silly size core and pipe work a front mount should work fine but if you dont want to go to that trouble there is no reason why an after market top mount will not do a fine job with an after market scoop
+ water spray kit would not go astray
zorak
Jun 5 2008, 02:35 PM
only answer is run the thing on methanol.........
tas_corolla, waterspray kit on a dragstrip is a no no
maf14h
Jun 9 2008, 08:38 PM
i'd say front mount! suck all that air in the atmosphere dude!
91gxlib
Jul 19 2008, 10:34 PM
Using a flipped core fm intercooler you could shorter you cooler piping to around 1.2m, match your pipe id. according to power and have minimal lag increase.
REXCE
Sep 10 2008, 09:16 AM
it will all depend on how much air you want to cool .
on a wrx the std tmic is shit you have two choices.
1 upgrade to a sti tmic or process west
2 upgrade to a fmic.
now i have done both options the tmic is very good for tight corners but besides that the fmic is all over the tmic every where else.
i picked up around around 200-300rpm of lag and 15kw with the fmic on a 05 .
but once you get to 200wkw on a rex you need a fmic to push any more a sti tmic can get you to 200kw but it's not safe to push it much more .
also any turbo over a vf22 you will need a fmic also the volume of air is just to great for a small tmic.
247PSI
Jul 30 2009, 10:01 AM
wat REXCE said.... top mount you get boost alot quicker due to shorter piping , i say the process west TMIC FTW! unless you get some custom piping for the FM and make it as short as possible.
dsleez
Sep 25 2009, 06:50 PM
from what i have learnt as has been mentioned, the TMIC is a much more responsive setup, but the FMIC will give u better top end power and response... am i right?
