garthkates
Jan 13 2008, 12:47 PM
never run a 1/4 before and was just wondering about something. can my wheels be turning before i get the green light if i'm crossing the line ??????
blacktrack Mal
Jan 13 2008, 03:16 PM
QUOTE(garthkates @ Jan 13 2008, 12:47 PM) [snapback]1281807866[/snapback]
I dont understand , can you explain that a bit better please
TuFFvs
Jan 13 2008, 04:30 PM
he wants to know either can he be doing a skid at the lights OR ! can he get a run up answer is no and why would you want too ?
garthkates
Jan 13 2008, 04:50 PM
no if my car is still but my wheels are spinning. my cars an auto
blacktrack Mal
Jan 13 2008, 05:39 PM
QUOTE(garthkates @ Jan 13 2008, 04:50 PM) [snapback]1281808471[/snapback]
The strat line beams work off your front wheels so if the back ones are spinning it is technically not going to affect the timers. Is that what you meant? I am still struggling to understand here. Most drag cars are auto's !!!
garthkates
Jan 13 2008, 10:41 PM
yeh thats what i'm saying, is there a rule saying i can't do it. my car has standard auto no stally.
TopAlcoholic
Jan 14 2008, 06:35 AM
I think I know what you mean.
Mal, you know when you see commodores or falcons (these are the main cars I have seen do this) come into to stage, one foot on the brake, one foot on the accetarator, start to build their rev's up and their rear wheels start to turn. Not hugely just enough to turn not dkid or move the car
Our VN used to do this and did not affect anything as Mal said, the staging beams go off your front wheels alone
TuFFvs
Jan 14 2008, 11:20 AM
but its pointless why do it ? its not going to improve your et other wise if it did i wouldnt have got a 4200 converter and trasbrake built c4 i would of jsut stuck witht he 4l60 and shift kit ...
Rapid Axe
Jan 14 2008, 04:49 PM
QUOTE(TuFFvs @ Jan 14 2008, 11:20 AM) [snapback]1281810990[/snapback]
I beg to differ.
Leaving the line with revs rather than just driving off will drop your ET. Case in point, my old AU ute I had, drove off and got a 16.7
Left with revs under the belt and got a 16.3, pathetic times yes, but thats besides the point.
garthkates
Jan 14 2008, 05:27 PM
i agree launching at 2500rpm is obviously gonna be quicker than 1000rpm (or under).
15uzu
Jan 20 2008, 06:23 PM
I think you guys are missing the point.....if your wheels are turning before you have any forward momentum you are only going to make it harder to get any. While there is always a percentage of "tyre slip" factored into a good launching car, there is a reason you don't see
ANY Group 1, 2, 3 or 4 drag car doing what is being discussed!
Spend the money & get some stickier tyres & a slightly higher stall converter.
TuFFvs
Jan 21 2008, 09:49 PM
QUOTE(garthkates @ Jan 14 2008, 05:27 PM) [snapback]1281812341[/snapback]
buh bow ! wrong haha its called a converter it will flash up to that stall speed witha big mash .. example my rig on an 11 psi tune 11.80 with a 4800 transbrake launch on PUMP fuel and a 11.90 driving it off the line now you cant compare a transbrake to stalling it up ont he foot brake but you get the idea theres not aot in it its pointless .. IMHO if you boys are running the times you are and wnat to make the times better.. spend the dollars ... jsut my opinionbut hey who am i to tell any one how to race i only crew on a group 2 car...... and 3 st289 cars..
garthkates
Jan 22 2008, 11:08 PM
i'm sure you know alot about drag racing good cars. of course a stall converter would be faster but its just common sense (in my car anyway)
Smokin Racer
Jan 30 2008, 11:04 AM
QUOTE(garthkates @ Jan 22 2008, 11:08 PM) [snapback]1281843392[/snapback]
My advice is stall it up but don't let the wheels break traction - Everyone laughs at the cars that have a sad little line lock going at the lights before they leave the line.
wadragracing
Jan 31 2008, 06:29 PM
QUOTE(Smokin Racer @ Jan 30 2008, 12:04 PM) [snapback]1281872442[/snapback]
Best advice of the thread.
garthkate, any benefit your car has from leaving with the revs higher will be nullified by the time you lose having the tyres spinning.
Just go to the startline, stage the car, press the brake has hard as you can and then push the accelerator slightly, then slightly more, as much as you can without the car creeping forward or having the tyres spin. Once you work out this sweet spot you will be getting good times consistently.
vh-holden
Jan 31 2008, 09:27 PM
I've seen a car doing that at the drags. I think it might have something to do with the guy driving getting out of 12 months home detention for ecstasy dealing that week and hadn't quite got the hang of his new 200sx.
51MPL
Feb 3 2008, 12:47 PM
sorry offtopic but is auto DEFINITELY faster than a man trans down the 1/4? couple ppl at my old work seemed to think man was faster and i cudn't b fucked telling them otherwise
15uzu
Feb 3 2008, 12:57 PM
QUOTE(51MPL @ Feb 3 2008, 12:47 PM) [snapback]1281887799[/snapback]
How do you figure that?
TuFFvs
Feb 3 2008, 10:33 PM
its not soo much that its faster ... its jsut alot ALOT easier to get down and better for changing .. i.e no clutch no drop in revs not a great deal of movment in the shift autos are better upuntill you start runing things like lenco and liberty shifted transmissions like prostock cars and other droup one cars then you get to the top of the tree with top fuelers which have 2 speeds forwards and backwards... and its all about timing the clutch plates to come in at the right time withthe right amount of pressure.. imho auto much faster for a street car with a reescpectable amount of power
14MYL
Sep 7 2008, 10:26 AM
Autos are better for drag racing. as consistancy will get you the win in bracket racing, not power.
obviously autos are more consistant with no room for error. Launch at same revs, change at same revs then it just comes down to the reaction time.
HZ_aretheway
Jun 14 2009, 09:13 PM
on the man/auto thing im pretty sure the group 1 cars are manual and they dont run a clutch and the gears are run through compressed air somehow but not really sure aye
just thought id throw that in there
HZ_aretheway
Jun 14 2009, 09:14 PM
i know some or all of the b&l cars run like thiss
