Full Version: Another Dunnydore Wannabe Drifter
LowVp
guys i have a vp ute with a turboed 6 knocking out 190rwkw, its on superlows with 31mm front sway bar to knock some over steer out of it as most know they like to steer themselves threw corners. its a 5 speed with 3.45:1 LSD is there anything else i can do to get it roughly set to drift apart from a strut brace.
Robby
drive it, have fun n get used to it... seriously... just have a play n thinker with it form there
nut024
poly urethane bushes right through out the ute and good steer tyres and alingment
LowVp
QUOTE(nut024 @ Jan 9 2008, 09:30 PM) [snapback]1281797658[/snapback]
yeah i think its all been bushed, i'm not sure of the brand but they are a blue/green color, would it be worth my while gettin adjustable strut tops to crank more camber in and possible the VR/VS lower controls arms as well as i think they are longer then the VN/VP
sidewayz
u can buy front camber kits for them.
adjustable swaybars at both ends, so they are 'tuneable' to a degree
good steer tyres and a decent wheel align
make sure the lsd is nice and tight, shagged lsd's are dangerous to drift with.
prehaps a good bucket seat to hold u nice and tight
and more then anything, just take it out to the track and have a go, u wil soon find out its flaws. wink.gif
NISMOgemini
paint the bonet black
B Unit
Perhaps a NISMO sticker lol
Just kidding, get it out there and see how it goes and make some adjustments from there.
1jz-vs-wagon
QUOTE(B Unit @ Jan 19 2008, 01:55 PM) [snapback]1281829651[/snapback]
LMBO LOL
littlegimp
cut the springs and weld up the diff
evl_ways
no ones going to crack a commy joke? this world is finally looking up! ...nice power figure tho
LOWGM
get rid of the dicky cable handbrake commodores have. hydraulic jobby is the shot, no more oversteers.
25YKU
get some drift stickers uleh
EK1.6LCIV
Please take some pic of this beast, Im curious, buy a decent seat as well, possibly invest in a cage
LowVp
henz
sounds tuff on the dyno
ash_s13
stiffer suspension
shiftmad
QUOTE(LowVp @ Mar 2 2008, 08:06 PM) [snapback]1281994257[/snapback]
LowVp
i haven't tried it yet, but i just want to be prepared.
1jz jzx90
put a vtec sticker on it YO
Wraith
Sell it and buy a skyline ph34r.gif Jokes get used to the way it is and once you feel it needs improving do it.
rayder
um just so you know, the vr/vs lower control arms aren't interchangeable with vn/vp ones. but..... you should be able to change to the vr/vs lower arms if you use the vr/vs struts to suit because they go together differently. that means changing the strut tops to the 3 stud vn/vp type. but you then also have to change the steering rack to a vr/vs one because the rack joins at a different position to the vn/vp one. but that may be just a waste of time because i'm pretty sure the track on the front end is identical from vn-vs. well thats my 2c and something for you to ponder on. smile.gif
QUOTE(LowVp @ Jan 10 2008, 06:07 AM) [snapback]1281798210[/snapback]
LowVp
thanks for the info rayder, i haven't spent much time under the vr/vs to compare them but i did know that they had a slightly wider track at the bottom but didn't know that that is wasn't interchangeable.
rayder
well as i said, they are interchangeable but you need to change pretty much everything else but the k-frame with it. the only reason i know this is because i used to pull them apart for a living and i was going to do the same thing on my vn.
HEAVEN
Sounds tuff in real life.. was up behind it through Inala/Richlands area in my daily coming back from work a while ago, sounds real tough mate, as for mods, a decent seat, and in my experience a half cage/ some sort of chassis bracing helps heaps.
Ronnie_Rampage
noltec solid strut tops allow your to fit vr/vs struts into vb/vp commodores but they are pricey at about $600pr
Timmyp34
a bit of topic but can you drift utes in comp in aussie?
i knwo u cant in D1NZ
88_vl_bt1
dunny dore? lol you import drivers are fucking dickheads "i dirve a n/a skyline like every other skyline on the road just to be diffrent" "my r31 makinf 23fwkw is so sick"
dickheads.
cmelsd
i out drift every car in victoria in my smart car everyday of the week stock with hydrolic handbrake
Timmyp34
QUOTE(88_vl_bt1 @ May 6 2008, 03:30 AM) [snapback]1282290827[/snapback]
dickheads.
What a fuck tard.
and every one knows skylines dont come in FWD and who the fuck would convert it to FWD dunno.gif
bustage
dickheads.
i believe the owner of the commodore called it that. So i don't know what your crying about
RUM PIG
dude i had a vr ute manual v6 with only a few mods like suspension and exhaust n it was awesome fun, way to easy to slide out. just take it out and go nuts! put some stockies on the back theyr like ice compared to the flash tyres
LowVp
its like i'm on ice with 235's under it won't be long now, just got some small jobs to get done and i should be out there giving it a crack
Kustum
you can use a ute in Drift australia, the capa ute compete's every round, plus all the demo work. Hang on, that makes commodores the most succesful drift chassis does'nt it (50man, Bolger,Mingay) not to mention 2nd best engine (50man, Bolger,Mingay,Elhouli, that 300zx)
Casper_101
Umm sorry mate^^ capa ute doesnt compete and hasnt competed in a few years. Mingay and Bolger use fairly stock VZ utes for the ute demos they do, but neither are running LS# engines in there drift cars only Elhouli is running an LS2 and Mackie in the 300 is running an LS1.
No sure bout utes in D1NZ but hamish marsden is running a Onevia Ute this season so not sure if that counts as a ute or not.
Btw theres a guy in NSW who used to drift WG spec VR 5L ute wit basically no mods and was doing extremely well, but moved onto other cars.
45DEG
did i read that right? did he just call import drivers dickheads? last i heard skylines are an import! ....
just take ya ute out and have fun..thats what its all about..GL
