fullboost
Dec 13 2003, 03:58 PM
i just opened my kickpanel to check out my ecu and revealed an aftermarket blitz computer which i had no idea was there ! ! !
so far ive found out -
The Blitz Access computer does not rely on fooling the ECU with external clamping circuits or making sensors read differently, it properly re-programs the factory limits, and all the fuelling is adjusted accordingly. The Boost limits are raised, the speed limits are removed, the rev-limiters are raised, the timing maps optimised, and the fuelling maps are adjusted to cope with higher boost.
FITZY
Dec 13 2003, 04:08 PM
what sort of car is this in?
fullboost
Dec 13 2003, 04:09 PM
180sx sr20det ...
u heard of em before ?
fullboost
Dec 13 2003, 04:10 PM
i just found out they are worth $1800 brand new so was a nice little find ..
i was gonna try and hook my apexi rsm into it , but im not gonna touch it now it has that computer in it ..
ill take it to someone to put in lol
the red krawler
Dec 13 2003, 04:14 PM
Well I found out the following from a jap website.
CHOONG NOONG NANG PONG FANG WING DONG TWOAR FOAR BING FONG TONG CHONG.
Thats all I can figure out from a page full of little stick men fighting each other (which they call an alphabet).
http://www.autov.net/Brand.asp?BrandID=2111| QUOTE ("According to bablefish.altavista.com....") |
Access fed back the know-how which is obtained from the circuit entirely, it is スーパーコンプリートコンピ�…ーター. From the test which is repeated under all condition, safety and maneuverability were overtaken thoroughly from race/lace and circuit travelling to the winding load. The function which corresponds to all round, power and safety - is compatible the run, furthermore evolves drivability.
< Feature > - The fuel following rise which corresponds to all round. - Speed limiter cancellation. - Rpm limiter modification. - The ignition type rise which corresponds to all round. - Boost limiter modification.
ACCESS 333R - The setting of ACCESS COMPUTER can be received with the nearby shop. - It is born in ACCESS COMPUTER which because of this is adjusted to the vehicle of the customer and changes. - Because the fuel map and the ignition map, modification is possible concerning data modification, also correspondence to the bulk injector is possible. - Engine tuning, the case of specification modification of the intercooler and turbo modification etc. you handle, the store and consultation. - Object model is only the Toyota car. - You handle and the store collects from midst of the BLITZ MAP NETWORK store. Please inquire details to our company.
* Price is turn-in value.
TougeS15
Dec 15 2003, 10:15 AM
Hey dude nice find!
Chiptorque are the distributors for Blitz in Australia. Call Stephan on (07) 5596 4204. He should be able to help you with any questions you may have.
Im pretty sure its a stand alone plug in computer. I have them in my Blitz Powerbook but no one has ever asked about them.
20VGT
Dec 15 2003, 03:51 PM
I beleive the system for these computers is that the customer goes to a blitz dealer (in japan) and tells them all of their modifications and they design an ecu to suit.
Fitting your RSM should be no problem as they run the same plugs as the factpry ecu. A friend of mine has an access ecu along with an RSM....no probs
They may be $1800 new but the odd bargain can be found......Another friend of mine bought one from a dismantler that obviosly did not know what is was.
For $250!!!!!!
hihosilver
Dec 16 2003, 10:31 PM
that is a good find, you are a lucky man. it would be doing its job just fine
TurbostyleR
Dec 16 2003, 10:35 PM
ive got one in my car...
i even took it out and opened the thing up and had a look and sure enough its all there, so i put it in my mates 180sx and it made a big difference...he could now chirp gears where before he couldnt....pretty good for 10psi and and exhaust i thought and it also made the thing rev smoother
GaryD
Dec 17 2003, 07:04 AM
prolly wont be able to get them retuned in australia id say
zigg
Dec 17 2003, 08:26 AM
I also had one in my 180. They probably have a unique program for whatever mods you have requested, but the biggest difference I found was no speed limiter.
Have since removed the daughterboard and replaced with a badbiki, with standard tune and the hi-boost rom that is getting about. I found the standard to be a bit laggier but comes on hard compared to the blitz. I also found the blitz to ping in real hot weather/ go into low octane mode no matter what fuel I put in - its probably better with hi-octane (100+) jap juice
