Prerequisites: Requires 200 Posts
Outline: Forums -> Edit Profile -> Custom Member Title
Discription: Custom Member Title is located under your username. Please use common sense regarding the choice of words used, if you are unsure weather your title will be offensive please contact a moderator for help.
Steps:
- Select Forums located in the Top Header
- Scroll down and select Edit Profile <---- Shortcut
- Input your required selection into Custom Member Title
- Select Amend Profile to finialise the amandments
