Full Version: Apexi Electronics
Boostcruising.com > Classifieds (For Sale/Wanted) > _,.:For Sale from our Sponsors :.,_
Street Tuned
All prices are subject to change depending on the YEN exchange rate.
Apexi Power FC - Click here for more info and compatability - From $1 000, (Most units $1 100)
The Power FC proudly stands as A'PEXi's answer to the constraints and limitations associated with most piggy-back style fuel controllers. The Power FC is a complete, stand alone, total engine management system capable of handling virtually anything thrown in its path. From multiple point fuel and ignition control to VTEC engagement (Honda applications) and boost settings, the Power FC is capable of accommodating even the most demanding performance enthusiasts.
Apexi RSM - $320, Optional G-Sensor $95, Stand $39
The new Rev/Speed Meter GP is a complete multi function measuring device designed to measure and monitor data such as vehicle speed, engine RPM, and elapsed times. The new unit also delivers a host of new functions. Standard features include: Engine RPM, Vehicle Speed, Travel Distance, and Battery Voltage (All which can be displayed in real time graph mode, numerical mode, or analogue mode; 1-4 channels at a time.), Peak Hold, Replay (With 60 second playback.), Speed Limiter Cut, 0-100m, 200m, 400m times with trap speed, 0-100km/h, 200km/h, 300km/h times, 100km/h, 200km/h, 300km/h E0 times, user defined Mid Range Acceleration, Stop Watch functions, Best Time Memory, RPM Warning, Speed Warning, RPM and Speed Outputs (For external devices requiring an RPM or speed signal.), Tire Size Correction (For acceleration and timing accuracy.), and Vehicle weight input.
[img][/img]
Apexi AVC-R - Click Here For More Info - $650, Stand $39
The AVC-R is a digital boost controller that allows the user to modify the boost pressure level on turbocharged vehicles. While there are many boost controllers on the market, none of the other includes as many features as the AVC-R, period. Despite all of the complex features included the unit, the AVC-R is flexible enough to be used by beginners. Entry level users need only to input a desired boost level and the AVC-R's trademark self learning CPU processor does the rest.
Apexi Super AFC NEO - Click Here For More Info - $599,
The SAFC NEO marks the newest edition to the world famous Super AFC line of piggy back fuel controllers. Building upon the powerful SAFC II, the AFC NEO has taken piggy back style fuel control to a new level. The AFC NEO boasts an incredible 16 points of user definable fuel correction. VTEC control has also been incorporated for Honda/Acura applications. A complete monitor mode is also available to keep the driver/tuner informed of critical engine data.
Apexi Auto / Turbo Timer - $150
The Apex Auto Timer allows the vehicle to idle for a preset amount of time after the ignition key has been removed. In turbocharged vehicles this prevents hot oil in the engine from coking up in the lines. Hard driving can raise engine oil temperatures to dangerously high levels. Proper cool down is essential for a healthy turbo and engine.
EL Series II Gauges - Gauges From $170, Control Unit $140
The EL II System Meters are the newest addition to the EL Meters lineup. The 60mm System Meters utilize a main control unit which constantly monitors the movement of all of the gauges. The control unit can activate the memory replay, warning, and peak hold functions with just one touch. The synchronized memory playback function was designed exclusively so that drivers did not need to individually start each meter before a race. A high speed CPU processor ensures accurate monitoring every time.
Please Note: The Mechanical Boost Gauge Does not need the Control Unit, but all other Electrical gauges including the electrical boost gauge do require the control unit, this ensures the most accurate readings as well as safety in the case of an accident (cheap mechanical oil pressure runs hot oil to the gauge in order to get a reading which can leak in the event of an accident)
Street Tuned
El Gauges Added
bigg_d
Hey,
Have you got any power FC's for an R34 GTT?
Thanks.
Evo Coupe
There wouldn't be any chance you can get parts???
I am in need of a preassure sensor for an AVC-R.
Street Tuned
Pm Sent, prices updated
M.L.E
can you get rb20det??
Street Tuned
QUOTE(M.L.E @ Aug 13 2007, 08:46 PM) [snapback]1281330857[/snapback]
Can I get what for an RB20DET? If you mean Power FC then NO they dont make them anymore. If you mean anything else including SAFC Neo which will do the same thing then YES.
Street Tuned
Please note guys for vehicles that Power FCs aren't supported
an Apexi NEO will certainly be suitable
fat180
Do you also tune or know of someone who is good at tuning the Apexi S-AFC NEO ? I understand this is a piggyback unit, so will it take care of a N/A engine, converted to turbo ? No-one has been able to answer this question for me.
Street Tuned
QUOTE(fat180 @ Oct 22 2007, 06:01 AM) [snapback]1281551788[/snapback]
I personally would recommend MATT SPRY at PITTS, but CNJ motorsport, APC or Mercury Motorsport should be able to do it.
HYN21
can you just get the hand controllers for the power fc??
EVL-200
can you get a power fc d-jetro for an s15??
stephen16
is there a power fc model for s5 rx7
Special Ed
Hey dude can you do me a quote on the following please...
RSM, G sensor, stand, Apexi Exhaust Temp, Oil Pres, Elec Boost and sender unit. (white face)
Any discounts for a bulk buy like that?
Regards Christian
Street Tuned
updated
Takumi101
whats the lowest you can go with the safc2?
Street Tuned
QUOTE(Takumi101 @ Mar 6 2008, 06:15 AM) [snapback]1282010271[/snapback]
Dont make them anymore
Have been replaced with the NEO
lancia19
do you have a power fc for the ca18det nissan?
NiSSaN_BoY
price on power fc for 34gtt
'JayRad
can you get the black RSM's in?
Club Spec6
are you able to get spare parts for EL2 gauges ie, sensors and looms?
1slp80
do u have el2 series in stock /boost oil press and water temp?
also rb25 series1 pfc?
Street Tuned
can get the gauges no worries
PFCs please PM me, I can't get ANY PFCs that are discontinued period
YES i can get black RSMs,
Please PM me
yes i will do a special price for large buys
Street Tuned
Updated
032PWR
can you get the boost control kit for my power fc? its an rb20det power fc. cheers
ras
hey man an you tell me how much it would cost for an Apexi power fc+controller for an series 8 01 mazda rx7 13B-REW. thanks.
4RCFED
will that afc neo pretty much allow my standard rb20det a31 to be tuned by most places then? without getting a haltech or something to a certain extent?
joonsing
what's the lowest price for the SAFC Neo?
does the price including delivery to Brisbane area?
cheers.
Street Tuned
hey guys please PM me any queries no need to post in here
Street Tuned
Updated everyone take advantage of these YEN busting deals
Street Tuned
These are some of the cheapest Apexi electronics on the net
DC2R8D
do u hav one for a DC2R TYPE R??
how much n how long will it take to get
offtaps13
i have a blacktop sr turbo from 180sx in a s13 converted from auto to manual and 1.8-2L wat can u recomend as the best computer to get and how much. also will this help to get my tacho workin or is that another issue. all work done by previous owner.
offtaps13
can u send me a quote with account details on a power fc and delivery to gold coast 4211. thanks shaun.
Street Tuned
QUOTE (offtaps13 @ May 7 2009, 05:15 PM) *
For what sort of car Shaun?
TheShadowOne
Can you please send me quotes on the Djetro and standard power FC
Car: 180SX 1992 Redtop SR20DET KRPS13
Thanks
tasevo
Hey buddy!
I got an Evolution MR 8, I am looking for a new computer could you please quote me Apexi Power Fc with boost controller PLEASE. Cheers
Street Tuned
Updated guys
gt35
hi i want a apexi neo price delivered to 4655 qld.
evopowa
ordered ev11v2 off this guy, honest seller...got the full package for a very good price & will recommend others thumbsup.gif
Street Tuned
updated
Club Spec6
how much for a white face oil pressure gauge?
FiL0_R32
Hey mate, I PM'd you regarding the different power FC's and prices for a 32 GTR (standard and d-jetro), an AVCR and a boost gauge. Let me know what im looking at. Michael
Street Tuned
updated
woodz_s13
hey mate i need a price on a pfc for a s13 sr20det delivered to nsw 2650
also does this include a hand controller?
