Full Version: Air Bags
jimbothepunk
howdy
just wondering what the difference is between dual and single port bags? (if any)
or if theres any pro and cons
thanks
lucas
wanker
I'm running Slam Specialties single 1/2 port bags in the front and rear of my lux (slams give you extra lift)! Also a 5 gallon and two 3 gallon tanks all hardlined with 3 compressors! Not to shaw on the difference between dual and single port bags! These question can be answered at www.downundertruckin.tk!
jimbothepunk
sweet as
must post sum pics
lucas
luxalicious
u can run ur dump and inflate valves seperate instead of having to tee ur valves, makes for a neater/quicker/less to leak setup
The Mexican
It depends on how you look at it. As Luxalicious said you can run a both valves off the bags or you can run double the valves which in turn means double the air equals air time. LOL
