Full Version: Help Asap 180sx Taillights And Headlights
My-St-OrM
Tail lights and dashlights not working. checked the fuses under rightside of dash. all fine. no wires unconnected (as far as i could see.) There are bigger fuses behind the smaller fuse box though. if they are them plz let me know. looked at fuse boxs under bonnet. no sign of tail light or dash fuses under bonnet. plz help asap.
Mystorm
20Hurtz
have you installed anything new recently?
Rookie ROX
How did you check the fuses?
Do you have a wiring diagram for the car?
I'd recommend doing a Google search or hitting up one of the 180 related forums and searching for a wiring diagram. That will then be able to tell you exactly what fuses are relevant.
If that's all too hard, next bet is to simply use a spare use (if you've got one - if not, buy a couple, should always have some spare fuses in your fusebox) and swap out a fuse at a time to determine whether one is blown. Just make sure you use the correctly rated fuse for each one wink.gif
ROCK ON
R~R
moe002
I had the same prob with my Rolla not all that long ago...
Whe I had installed a oil pressure and then a boost gauge, a + and - wired were touching and kept blowing the fuses!!!
Have you installed anythign electrical lately?
TristanM
same thing just happened to me when i put a sub/amp in my car? Anyone know what the problem could be all fuses are fine!
Audio Express
some one treid to put a radio in I believe. look at the fuse panel at your feet, you have a blown fuse. pull and inspect every one of them!
TristanM
no but all of them are fine :S
TUN35
QUOTE(TristanM @ Jan 3 2007, 09:41 PM) [snapback]1280633314[/snapback]
Have you just come to this conclusion via a visual inspection?
TristanM
yeah... i pulled them all out and looked to see if they are broken.?
TUN35
A visual inspection is never accurate. It's best to grab yourself a multimeter and test it for sure. See the following thread for what you need to do to test one smile.gif
http://www.boostcruising.com/forums/index....showtopic=61739
obrim
Multimeter or even just a test light.
bomb250
yeah never visually inspect test lights nice and easy to test continuity between the terminals off fuse if thers power there . 9 times out of 10 the problem you described is just a blown fuse . but if the fuse is not blown find the parker/tail light relay , with your lights on you should have 12v at three off the terminals 85or 86, 30 with power coming out at 87 being a factory relay they probably wont be marked so just check for power
