Full Version: Fuel Tank
Boostcruising.com > General Forums > General Discussions
MrVlt
I have a new fuel tank for a vl but i dont know how to get the other one off can someone please help me
TUN35
Moved to General Discussion
Cookie
bit of advice mate, there a bit of a bastard to do, as the breather hoses and the 3 other smaller breathers are routed through a small hole in the chassis rail, its not the easiest thing to do, i had troubles and i done it on a hoist with the tank on a gearbox jack..
the 2 metal straps that hold the tank in are easy.. its the hoses that are the problem.. id recomend goin to holden and getting the 3 new small breather hoses and the larger breather and taking it to a workshop and get it done properly...
it would be an absolute bastard to do on the ground.. i wouldnt atempt it without a decent amount of knowlege..
pain in the arse raiting out of 10, 9....
the bomb
what type of tank is it
yo im new to the site can some 1 answer me
p:
bigafoot
Done it before on the ground just jack the rear of the car up support it all on wheel stands, and get another one for under you tank and away you go.
It is a bit of a prick to get the breather lines through the rail but patience and you will be able to do it after all it just clamps and hoses nothing special. Make sure you have a full diagram of where the hoses are to go and dont get any of them kinked.
I had to replace mine after they where perished. I would not be paying holden or a workshop to be doing this as its easy enough to do it yourself.
