bodgily installed and the major problem was rattling and vibration in the door
trims. So I set out to sound deaden the doors as proper as possible, and replace
the splits with some nice Focal 165hs. So here I will describe the process of
installing the speakers along with how I sound deadened the doors. You will need
everything here, which you can source from your local Autobarn or similar.
If you have speakers that are too deep or need to be adjusted to fit properly, you
will also need some 18mm MDF (or appropriate) to make some speaker spacers out
of. Do not use the cheap dodgy plastic speaker spacers, that will only result in
heartache. First, remove the door trims, underneath, in my case, you get to see
the previously dodgy installation. To get the door trim off youll usually find
at least one screw that holds the handle and/or the trim for the door
handle/lever. Youll need to remove them and then pull off the trim. This is
going to be different to a certain extent from car to car.
Firstly, deal with the doors. You want it to be as airtight as possible, so using some
thin sheeted MDF may be appropriate for sealing up some of the gaping holes in
the door. This is definately an optional thing to do and Ill leave the decision
of whether this is worthwhile compared to ventilation and water seapage issues
compared to slightly improved sound from your stereo up to you.
Having it all sealed up makes applying the spray on sound deadener much easier though!
Remember that this stuff is also waterproof and all the rest, so go to town with
it, but prepare your area properly. You don want to ever see evidence of the
sound deadener when the trim goes back on so use LOTS of paper and masking tape
to create an outline.
Spray it all on, and even go inside the door as much as possible, taking care not to
spray it on the window winding mechanisms etc. And you e end result will look
like this. In my case, since it was a black car, the change isn very noticeable,
but imagine if you have a white car and you sprayed this stuff accidentally
elsewhere, horrible! So be careful!
Now you want to do the same sort of procedure to your door trims, but this time do
it much thicker and do it with the paint on sound deadener that comes in a tin.
This stuff is very thick, and it will destroy a paintbrush. So be prepared to
not use the paintbrush for anything else again. Prepare the trims with masking
tape such as below and then go to town..
After applying it all and then removing the masking tape, youll get something similar
to this. Remember it is thick stuff but it spreads well. The directions on the
tin will tell you how thickly to apply it but the thickness is hard to control,
it basically goes on thick and thats what you want anyway.
This is where I had to build some spacers for my speakers to make sure the speakers magnet wasn't in the way of the window winding down :-) ... this is moreso part of my speaker installation that happened while doing the sound deadening, so I won't concentrate on this too much.
Then its time to fasten the speakers into the door with the spacer. Test fit the
speaker to make sure that the window will wind up and down without any problems
before fastening it permanently. Also with the speaker test fitted, test fit the
door trim to see if it sits over the speaker and clips into place. To fasten the
speaker there solidly, you will want to use some long bolts with nuts and
washers. Use two nuts per bolt and do each nut up one at a time, this way it won
rattle loose.
And then you e hopefully done. We haven covered wiring, or location of the tweeter,
crossover, etc, but this will depend on your individual installation (and
whether you have cross overs or tweeters, maybe you just have 2-way speakers!)
Then, with any luck, you can fit the door trim and enjoy your new install! In my case,
the speakers didn clear the door trim adequately and the cone of the speaker
actually hit parts of the door trim when producing certain bass. This problem
was able to be resolved but it was lack of test fitting the door trim that got
me into trouble.. something to keep in mind, test fit everything.
