1jz engine mounts - r154 gearbox mounts - 4wd hilux tailshaft cut down and balanced to suit r154 (wont break this) - 4wd LSD 4:3:3 dif gears spooled (wont break this but its a bitch to push around) - Alfa romeo slotted front rotors (these things must be 30-40mm thick) - gtst skyline front brakes with braided lines - brand new wilwood brake bias - rci fuel cell - battery mounted back under tray wired up to engine bay - fuel line oversized (1/2 inch i think) from cell to engine bay with copper return line, speedflow fittings (missing fuel pump had a 044 mounted near battery) - brand new ladder bars set up with x4 adjustment mounts so you can customise setup to track, street, drag, power etc etc... - leafy's reduced to x2 to help with traction - new pedders shocks mounted in the rear - new 90/10's (pedders up front) - oversize pedders sway bar - 90% of 4inch exhaust (sounded fat) - comes with full set of stocko 16 inch Aristo wheels some tyres fuckd and they are wrong offset but good for getting it mobile. - almost brand new mickey thompson et street slicks 325/50/r15 tyres mounted on 10inch wheels (wheels are alittle rough) was going to run convo pros on these tyres. - rust cut out and treated, black jacked behind gaurds and most of floor (cab needs alittle more work before ready for paint) stripped back to bare metal on 80% of body etched to stop any rusting! - Has all glass accept front windscreen - comes with doors and front gaurds
price is ono leave in two weeks so make a decent offer
^ Repayment examples are based on a Chattel Mortgage commonly used by businesses. Excludes fees and government charges, subject to assessment and approvals. Australian Credit Licence 392426.
