way too much money was poored into this car from previous owner, its modified, no expense spared. full street trim.fast,fun,sleeper,first serious contender to look at this car will walk away with a bargin.
***is rego'd and mod plated***
[ this is alot of fun to drive, and it defiantly moves if you want it too, buyer wont be disappointed ]
92 323 sp turbo (top of the range)
full electrics,sunroof plenty of time and money spent,clean and quick little car. comes with 17" wheels pics of how it sits right now..the pictures dont do it much justice,just quik snaps. all work done professionally WITH PROOF !!
front mount intercooler 600x300 and stainless steel pipe work(motion garage) turbosmart supersonic bov (plumb back) 550cc aftermarket injectors adjustable Fuel pressure regulator with pressure gauge walbro intank fuel pump IHI vj23 turbo ported wastegate gtr manifold port matched turbo stainless steel custom twin pipe dump 3" mandrel exhuast with high flow cat after market link fully programable ecu MSD ignition system red devil radiator new water hoses braided turbo oil feed catch can,no blow by new hydraulic lifters custom high flow oil pump gates racing timing belt k&n pod filter aftermarket race engine mounts front and rear(as standard ones dont last long) serviced and new oil every 3,500k(royal purple and motul turbolight)
gearbox/drivetrain:
(tighter box then your first root) new g series gearbox rebuilt,all new bearings PAR straight cut third gear,with double syncro Mazdaspeed LSD,welded ring gear custom passenger side driveshaft reco'd cv's and shafts short shifter n new bushes 28 spline cv's changed box oil reguarly NPC exedy heavy duty organic clutch with extra clamp pressure brand new clutch master and slave cylinders
Body:
full spray,gunmetal grey,$4,500 worth colour coded strips and bumpers new windscreen and seals
suspension: kyb struts all round super low king springs bump stops whiteline front n rear strut braces whiteline heavy duty rear sway bar nolthane new link bushes all round
brakes:
slotted rotors **brand new pads all round 18/09/10**
audio:
jvc cd/mp3 kicker splits in pods amp running splits 15" subwoofer pioneer amp running sub
^ Repayment examples are based on a Chattel Mortgage commonly used by businesses. Excludes fees and government charges, subject to assessment and approvals. Australian Credit Licence 392426.
