Looking to sell my 202 iv been building as i need the cash. This is the best base you can start with when building a 202.
The specs: Black 202 block 80thou high compression pistons (not flat tops) with moly rings ACl bearings, over size for the crank and pistons Crank has been balanced 30/70 cam. Power from 1500rpm but still with good fuel eco.
With a compression of 10.1 with some triple webber/stongbergs you can put out very close too 200hp with this set up. If you were looking for more, a bigger cam, higher compression and some tripple SUs will put you with even more power.
Can chuck in a 202 head with this bundle, but it needs a hardcore clean up.
Im asking $600. Iv have the receipts for all the parts which makes a grand total more then im asking.
(Lifters in the one of the photos are not included)
