Hi guys. I'm selling my turbo kit that I ordered for my 350Z. It's due to land on 3rd February 2011. It's a complete kit all you need to purchase is an aftermarket ECU.
Located in Brisbane. Payment $7,550 (I bought it when the dollar was strong)
The PowerLab GT35R Single Turbo Kit consists of only the highest grade quality parts and materials offered on the market including Garrett, TiAL, TurboXS and Walbro.
Benefits of using the Garrett Ball Bearing GT series turbo is increased efficiency and spool up time as well as reliability by using water cooled methods. Other Benefits include the largest fuel injectors offered of any turbo kit on the market in the form of 600cc Denso Injectors and a Walbro 255LPH Fuel pump for optimum fuel delivery. Stainless Braided oil feed lines for ultimate aesthetic and reliability purposes along with high quality custom extended A/C line, CNC Oil Pan Spacer, mandrel bent and tig welded Piping components as well as one of the largest intercooler cores offered on the market with minimal modifications needed to retain the factory crash bar.
PowerLab is one of the only companies to include TiAL Wastegates and Blow Off Valves as standard issued components in all of their turbo kits. A 50mm BOV and 44mm External Wastegate are used in the PowerLab turbo kit for their proven history of excellence and performance on forced induction applications.
PowerLab doesnt stop at fuel delivery and quality hard components as they have decided to include a TurboXS Map Sensor and TurboXS Utec Engine Management system complete with base map.
The GT35R Turbo Kit from PowerLab offers the most efficient and highest horsepower potential capabilities on the market. Whether youre looking for approximately 400RWHP on a stock motor or 653RWHP on a semi built motor and upgraded fuel components, then the PowerLab GT35R Turbo Kit is the kit for you.
Turbo Kit Features:
- Garrett GT35R Dual Ball Bearing Turbo with .82 A/R Turbine (1.03 A/R Recommended for built engines)
- TiAL MV-R (44mm) External Wastegate
- TiAL 50mm Q Blow-off Valve
- 23 1/2"x12"x4" Front Mount Intercooler
- Polished Stainless Steel Exhaust Piping with 3" Downpipe
- Polished Aluminum Intercooler Piping
- CNC Billet Aluminum High Capacity Oil Pan Spacer
- New Custom Extended A/C Line
- Stainless Braided Oil Feed and Return Lines
- All Necessary Hardware and Installation Instructions
- 600cc (Set of 6 direct fit) Deatschwerks Injectors
- TurboXS Engine Management Unit
- TurboXS MAP Sensor
- Walbro 255LPH Fuel Pump
- Currently tested on manual transmission cars only and with build date of Nov. 2002 through 2005. Does not fit Pre-November models without additional fabrication of bracket (AC compressor on Pre-Nov. Build Dates have only to mounting bolts compared to the 3 mounting bolts of later models). Optional 2006 kit available for an additional cost since power steering rack is different and requires additional modifications.
- Approximately 15 hour install time
- This kit was designed for 6MT vehicles, 5AT vehicles will require modification of the kit.
- If you are running a dual exhaust a reverse Y-pipe will need to be fabricated.
