Item Summary: Import Parts Sale Mostly Nissan (s13, r32, r33, wrx)
Condition: Used
Reason for Selling: Garage out no more use
Asking Price: 1
Delivery Methods: PickUp, will post small items
Contact Info: Call or text (XXXX-XXX-XXX), email or msn (XXXX-XXX-XXX), PM
Extra Information: add updated 28/01/11 all parts sold now removed
Garage Sale
Hey guys have decided to have a huge garage sale where i plan on selling most of my parts for reasonable prices, so if youre lucky you may pick up a bargin here! I have a lot of import parts, which will mostly come off and suit Nissan Imports however i do have other odds and ends which you may find useful.
R32 Skyline
Braking - R32 gts-t front rotors (pair) -$40.00 - R32gtr rear rotor (single) - $20 (slotted) - R32 gts-t front hard metal brake lines with fittings - $10 Turbos & Accessories - R32gts-t rb20det OEM turbo charger (blown exhaust wheel) - $30 - R32gts-t rb20det metal cross over pipe (throttle body to I/C pipe) stock with no BOV fitting RARE perfect to run aftermakret bov and look stock - $40 - r32 gts-t rb20det metal cross over pipe (TB to IC) with stock BOV, 50 Engine Parts - R32gts-t rb20det Timing belt cover (embossed rb20 & includes dust cover) - $30 - R32gts-t rb20det OEM throttle body - $30 - R32gts-t rb20det coilpack brackets x 2 - $20 - R32gts-t rb20det OEM intake manifold (with everything valves) - $30 - rb20det turbo fuel pump $50.00 - r32 rb20 standard cam gear - r32/33 turbo heat shield $20.00 - r32 full hi-has set up $40.00 - rb20det charcol canister - $10.00
Air-conditioning - R32gts-t Air-conditioning grille & line - $40 Body & Chassis Parts - R32gts-t rear suspension arms - $30 - R32gts-t rear cradle supports - $20 - R32gts-t gearbox cross-member - $30 - R32gts-t rear tailshaft (centre diff) x 2 - $20 each - r32 gtr dash cluster - minus tacho - $10.00
- Single DIN pocket $10.00 - JJR manual anodized red manual boost controller - $30.00 - anodozied blue pod filter $5.00 - Procomp Mechanical Oil Tempreture Gauge -$30.00 - Pivot turbo timer $30.00 - Blitz bolt on high flow pod filter $30.00
thanks guys!
I know there is no pictures posted here in this add, as u can imagine it would take forever to take them all and upload them so if you require photo's request the part you want and i'll send them to you some how or post them up! Also have more parts available so just ask please and i'll respond when i can! Pick-up can be arranged once contacted. Kind regards, Hame!
