Welcome Guest
Log In | Register
Start new topic
How to Replace your cars Thermostat
roweysvn
post Oct 24 2004, 06:01 PM
Post #1
Give me a kiss sweetheart.
Contributing Member!
Group: Retired Moderators
Off Topic Posts: 18,216
How to replace your cars Thermostat
After finding that my car was ready to blow up cos it was reading rediculously high temperatures and overheating, I was told my thermostat was most likely at fault so I needed to replace it. At only around $20 for a new thermostat, it was certainly worth a try!
In the first pic is obviously my engine bay, every cars thermostat is obviously going to be placed in different areas but in general, you follow the hose at the top of the radiator towards the engine. This hose will lead to the thermostat.
You need to make sure when doing so that the car is cold, so let it cool down or do it first thing in the morning etc.
You will need:
A new thermostat housing gasket
A thermostat.
8-12mm Sockets or spanners
Flathead screwdriver
I picked up what I needed from Supercheap Auto for about 20 bucks for the both. The gasket was self adhesive...
user posted image
This is where my top radiator hose connects onto my super dooper engine. The thermostat is located at the base of the thermostat housing, where the little arrow is, but is obviously inside. 2 Bolts is all the was required to take the it off but it was much easier to do when we disconnected the hose at the radiator, there will be some water loss, but not much when u disconnect it.
user posted image
Righto, trusty ole Ni_Slo used a screwdriver to pry the thermostat out, and it comes out relatively easily.
user posted image
There is a gasket between the thermostat housing and the engine, so u must clean both surfaces before you but it back on.
user posted image
And also clean off remnants left on the thermostat housing, this took a little while to get off as its pretty caked on due to heat.
user posted image
This is the old thermostat held up quite well as it appears pretty old and its a 13 year old car. It was pretty tarnished and yeh.
user posted image
Now, just put the new thermostat into the engine along with attatching the self adhesive gasket to the thermostat housing. Then you attach the housing so it looks like this. You then re-attach the radiator hose and do up the hose clamp reasonably tight, but don't take it to the extreme.
user posted image
So obviously some water had leaked out while doing this and air had made its way in, so we topped it up with demineralized water (or a pre-mix radiator coolant mix which is cheap from SuperCheap) and then my cooling system was doing its job running at a safe operating temperature, not one notch off the devestating "H" mark.
So all things aside it was a relatively easy job, i had Ni_Slos assistance and he knows what he is doing so all went well, and after all that the car was running sweet and should be back to this type of stuff in no time. Thanks to James (aka Ni_Slo) and poor widdle Amelia was stuck here on the intarweb while we went outsi de. Any questions feel free to ask. rowesyvn.
oo ee oo ahh ahh bing bang walla walla simtang!
Envy Ess Ohh FWOAR!!!!!
Go to the top of the page
+Quote Post
NiSlo
post Oct 24 2004, 06:06 PM
I'm just so Rad
Off Topic Posts: 4,039
+Quote Post
roweysvn
Just thought id like to point out, my engine is a series II model and the cooling system is a little different to that of a series I ive been told that the series I thermostat is at the back of the engine
Sucks the wang
Dave
+Quote Post
QuicKSilveR
post Oct 25 2004, 10:37 AM
ex FAN74 Laser
Group: Users
Off Topic Posts: 18
.....ANd to test the thermostat - chuck it in boiling water and see if it opens
2001 Nissan Silvia s15 - Black
2001 Subaru Forrester GT - Black (SOLD)
1987 Ford laser Tx3 Turbo FAN74 - Orange (SOLD)
+Quote Post
Pie
post Oct 25 2004, 03:41 PM
Senior User
Group: Region Moderators
Off Topic Posts: 670
thansk for the article, i need to change mine this week - NICE SKID TOO
IS B00ST - IS G00D
+Quote Post
bogan_boy89
post Oct 25 2004, 07:01 PM
Standard User
Group: Users
Off Topic Posts: 40
nyce, well that makes my job a hell of alot easier as i believe i have to the whole thermostat thing, so i will print this out and copy it, lmao, jj, nah but thanks for the pointers man, phat skid to. if i get stuck or bored ill call ya tongue.gif
bogans can drift
+Quote Post
amelia
post Oct 26 2004, 09:14 AM
Site Newbie
Group: Users
Off Topic Posts: 10
very good aritcle davey, but yes your right the thermostat is located at the back of the engine on the Series 1 model vn's, along with there is no radiator cap on the radiator itself, it is filled up through the overflow tank. biggrin.gif cool.gif
+Quote Post
LOW_CAL
post Oct 26 2004, 07:11 PM
ROW DAY HOE !
Group: Users
Off Topic Posts: 982
woot hoo series 2
i got a crappy series 1 sucks the wang allright have to take off the whole dam throttle body setup sad.gif
so much wasted time so much time wasted..
there is no finish line.............
+Quote Post
NAS733
post Oct 27 2004, 07:14 PM
Standard User
Group: Users
Off Topic Posts: 19
can now see how the first thermo fucked itself. hehe nice one dave... good to see the commo can still pull a skidddd rolleyes.gif
+Quote Post
DTrain
post Nov 6 2004, 12:12 AM
Standard User
Group: Users
Off Topic Posts: 3
might wanna give yourself a flush and some coolant, she looks a lil corroded
+Quote Post
king of the conc...
post Dec 3 2004, 07:27 AM
IH8WRX has been sold!
Group: Guests
Off Topic Posts: 975
Nice article Dave. Did you check to make sure the new thermostat worked before you put it in? Only asking as 1 in 3-4 new thermostats are actually faulty. Easier to place it in a cup of hot water to see if it opens than having to pull stuff apart again and again. Did you bleed the air from the cooling system or just left it?
Bite off more than you can chew, then chew like hell!
View IH8WRX here http://www.boostcruising.com/readersrides/entry/6/9374.html
+Quote Post
Slicer
post Jan 27 2005, 10:04 PM
Site Newbie
Group: Users
Off Topic Posts: 3
Did you put a vn engine in a camira or am I seeing things :S
One more such victory until we are undone
+Quote Post
Kai
post Apr 3 2005, 08:41 AM
Wheres my keys @#$!!
Group: Users
Off Topic Posts: 54,072
thats good
Mazda 808
13B Turbo
GT42R
+Quote Post
rolnlow
post Jun 15 2005, 07:57 PM
Standard User
Group: Users
Off Topic Posts: 25
weres the skid?
+Quote Post
TE72-TURBO
post Jun 15 2005, 11:10 PM
Budding User
Group: Users
Off Topic Posts: 0
It would also be a good idea to put it in a bunsen burner with warmish water but with wire looped around the part that opens and suspend the the thermostat half way up the glass then place the thermometer into the water, heat the glass up with a flame or on a stove top until the thermostat opens therefore drops to the bottom of the glass and record the tempreture at the time it drops and compare with the manufatures thermostat opening temp to see if it is not faulty. smile.gif
-Mazda RX7 Series II Daytona 12a Turbo.
-Toyota T-18 Rebuit 3TGTE
+Quote Post
Little Rippa
post Jun 4 2009, 05:33 PM
Site Newbie
Group: Users
Off Topic Posts: 0
just so i can get it right in my head...is that the L36 fireball???
+Quote Post
Sil-ider
post Jun 6 2009, 05:42 PM
Oh hurro!
Group: Users
Off Topic Posts: 190
Most certainly not.
It's a Buick 3800
QUOTE (GreekWarrior @ Aug 31 2009, 05:40 PM) *
i'm gona make a brand and call it vtec
QUOTE (B Unit @ Aug 31 2009, 05:56 PM) *
So it will be overpriced, not even any good, and popular with homosexuals? :oopsie:
Current ride:
-1992 Nissan Silvia
Previous rides:
-1990 Holden Nova
-2000 Nissan S13 Silvia (PM me if you wanna know) haha
-1999 Holden Commodore VT
+Quote Post
Mongrel
post Jun 8 2009, 09:17 PM
Cars everyday for work, rest and play!
Group: Technical Members
Off Topic Posts: 69
might want to add that not all thermostats are off the top hose, it can be either side depending on make/model.
The Mongrel.... Sold!
Mongrel 2.......Under Construction
+Quote Post
NOR011
post Sep 8 2009, 01:18 PM
It's not easy doing what I do.
Off Topic Posts: 553
Dont forget to bleed all of the air out of the cooling system.
QUOTE (bigjim @ Oct 8 2009, 10:59 PM) *
hay hay hay stop all the name calling hahaha.not all of us have half a brane mate.
+Quote Post
Reply to this topic Start new topic
> Fast Reply
Bold
Italic
Underline
Insert Image
Emoticons
Wrap in quote tags
Wrap in code tags
 Enable email notification of replies |  Enable Smilies |  Enable Signature
