Eze Gze's Nissan, S14 Silvia |
Nov 7 2009, 04:06 PM
Post
![]() Standard User ![]() ![]() Group: Users Posts: 91 Off Topic Posts: 0 Joined: 19-November 08 From: Melbourne Member No.: 149,093 |
Hi guys,
just posting this up for a mate so tell us wat ya reckon Engine: CP forged pistons 8.5:1 CR (available in 9:1 also) Brian Crower billet H beam connecting rods ARP head stud kit ARP main stud kit ARP2000 rod bolts Cometic metal head gasket King pro series rod bearings King pro series mains bearings Tahho thrust bearings Nissan Full gasket kit Nissan water pump Nissan oil pump Nissan s15 timing kit Nissan rocker arms GKteck rocker arm stoppers Brian Crower valve springs Brian Crower titanium retainers Brian Crower step 2 camshafts Vision adjustable cam gears Precision hydraulic lash adjusters SRC large sump (greddy style) SRNRG coil pack cover SRNRG oil filler cap T2871R Turbo Stainless exhaust manifold Greddy intercooler Z32 air flow meter Drift pod filter Sard BOV Braided turbo lines Replaced all silicone water lines Koyo radiator AU Falcon thermo fans 740cc Tomei injectors Weld ABS heat shroud Pully set Nismo thermostat Nismo engine and gearbox mounts Block cleaned and checked Block bored and honed Block tunnel bore and honed Block resurfaced with timing cover Crank crack tested and straighten Crank grind and micro polish Crank balance Piston balance Con rod balance Clutch cover, flywheel and harmonic balancer balanced Head clean and check Head resurfaced Valve guides k lined 3 angle valve cut Port and polish on exhaust Gearbox: S14 5spd, Ogura clutch, KAAZ 2 way lsd Exhaust: Xforce Turbo back exhaust, 2.5'' to 4'' tip Suspension:Cusco zero2 coilovers, cusco EDFC Wheels: Rays Gram Lights 57sPROs Front:18x9 0 offset Pirelli Pzero rossa Rear: 19x10 -13 offset No name lol Modifications: Stitch welded engine bay, S15 front end conversion, custom made front guards S14 to S15, D max bonnet with D1 bonnet pins, URAS side skirts and rear bar, Msport front bar, custom made rear widebody guards 60mm each side, inside of car painted black Interior: Stripped out rear seats and trim sound deadining, stereo, Bride Brix II seats on Bride rails, Defi link guages water temp oil pres and boost, GK tech steering wheel, PSI parts drift button, SR NRG handbrake and shift boots, EDFC, Power FC hand controler, trust gear knob, extinguisher, hektik cardboard insert where the head unit used to be haha Stereo Audio / Visual: as if Estimated Power: 241rwkw safe tune still being run in Future Plans: more suspension work, arms, swaybars etc, RB25 gearbox conversion, roll cage,harnesses, maybe convert back to series 2 front end, D max bootlid and roof spoilers This post has been edited by EzE GzE: Nov 7 2009, 04:16 PM |
Nov 7 2009, 04:09 PM
Post
#2
![]() Nebo Enthusiast ![]() ![]() ![]() ![]() Group: Users Posts: 587 Off Topic Posts: 64 Joined: 13-October 06 From: Brisbane Member No.: 54,109 |
this is good!
Nov 7 2009, 04:10 PM
Post
#3
![]() LAND OF THE LONG WHITE CLOUD ![]() ![]() ![]() ![]() ![]() Group: Users Posts: 4,321 Off Topic Posts: 230 Joined: 18-March 08 From: LAND DWN UNDER Member No.: 104,708 |
very nice bro
Post
#4
Senior User ![]() ![]() ![]() ![]() ![]() Group: Users Posts: 6,140 Off Topic Posts: 3,555 Joined: 16-August 05 From: mexico....well, capalaba Member No.: 30,049 |
wow! few bits don't do it for me, sideskirts look lower than front lip in some pics? very well done, love the wheels |
Nov 7 2009, 04:11 PM
Post
#5
![]() skid itttt ![]() ![]() ![]() ![]() ![]() Group: Users Posts: 5,538 Off Topic Posts: 5,176 Joined: 18-March 06 From: Gold Coast Member No.: 43,847 |
holy shit thats hot
Post
#6
![]() Standard User ![]() ![]() Group: Users Posts: 302 Off Topic Posts: 0 Joined: 18-January 06 From: In Da west Member No.: 40,271 |
ONE WORD SEX !!!!!!!!!
Post
#7
Standard User ![]() ![]() Group: Users Posts: 223 Off Topic Posts: 9 Joined: 1-May 08 Member No.: 115,011 |
looks awsome lovin the rims did u order them from japan? |
Post
#8
![]() New User ![]() Group: Users Posts: 40 Off Topic Posts: 0 Joined: 26-August 08 From: Clevetown Member No.: 135,527 |
pure sex
Nov 7 2009, 04:15 PM
Post
#9
![]() Mr sr20 ![]() ![]() Group: Users Posts: 368 Off Topic Posts: 1 Joined: 14-August 08 From: Mid north coast, NSW Member No.: 133,127 |
fuckin sex. get bigger turbo n new ecu and make heaps bigger figures
Nov 7 2009, 04:19 PM
Post
#10
![]() Regular User ![]() ![]() ![]() ![]() Group: Users Posts: 2,065 Off Topic Posts: 23 Joined: 17-April 05 From: Australia Member No.: 23,105 |
NOW thats how a car should be MODDED JMD inspired yall, I would repaint the wipers to black so it looks factory otherwise looks like an ricer civic with silver bit hanging out ! Top Notch !
Nov 7 2009, 04:21 PM
Post
#11
JDM AS FUCK thats right
Nov 7 2009, 04:33 PM
Post
#12
![]() Budding User ![]() ![]() ![]() Group: Users Posts: 1,046 Off Topic Posts: 306 Joined: 16-October 07 Member No.: 84,003 |
holy fking win!
Nov 7 2009, 04:38 PM
Post
#13
Regular User ![]() ![]() ![]() ![]() Group: Users Posts: 2,037 Off Topic Posts: 22 Joined: 6-April 05 From: COMPTON Member No.: 22,429 |
THIS IS HOW JDM SHOULD BE DONE!
Nov 7 2009, 04:39 PM
Post
#14
![]() Budding User ![]() ![]() ![]() Group: Users Posts: 649 Off Topic Posts: 1 Joined: 11-November 07 From: above you and your kind... Member No.: 86,890 |
probably the first car i've seen with a "JDM as fuck" sticker that actually deserved it..... i spose this car is simply....... all out.... more or less a rolling parts catalogue. the kind of car you'de build if you won lotto. .... i like it. -rtb. |
Nov 7 2009, 04:49 PM
Post
#15
Standard User ![]() ![]() Group: Users Posts: 72 Off Topic Posts: 0 Joined: 18-October 09 From: Brisbane Member No.: 179,356 |
Love the car! the rims are nice and gotta love it all together!!! nice ride!!!
Nov 7 2009, 04:52 PM
Post
#16
![]() Senior User ![]() ![]() ![]() ![]() ![]() Group: Users Posts: 3,934 Off Topic Posts: 7 Joined: 9-August 06 Member No.: 50,589 |
wow best s14 i have seen 2 date, love it
Nov 7 2009, 04:56 PM
Post
#17
Standard User ![]() ![]() Group: Users Posts: 65 Off Topic Posts: 0 Joined: 29-November 08 Member No.: 150,305 |
fuck fuck fuck fuck fuck thats the best looking s14.5 I HAVE EVER SEENNNNNNNNNNN!!!!!!!!!!!!!!!!!!!!!!!!! nicwe work bro |
Nov 7 2009, 04:57 PM
Post
#18
![]() Deus Ex Machina ![]() ![]() ![]() Group: Users Posts: 1,080 Off Topic Posts: 227 Joined: 15-December 08 From: Shangri La Member No.: 152,049 |
Very Nice... |
Nov 7 2009, 04:58 PM
Post
#19
![]() Standard User ![]() ![]() Group: Users Posts: 194 Off Topic Posts: 61 Joined: 16-August 07 From: Sydney (West) Member No.: 77,109 |
Ohh baby Me likey, Very Niceeeee Love them rims how much did they set you back??? |
Nov 7 2009, 05:00 PM
Post
#20
![]() Special User ![]() ![]() ![]() Group: Users Posts: 1,151 Off Topic Posts: 23 Joined: 26-December 07 From: Sunshine Coast QLD Member No.: 91,534 |
Nov 7 2009, 05:14 PM
Post
#21
![]() Standard User ![]() ![]() Group: Users Posts: 125 Off Topic Posts: 3 Joined: 5-August 09 Member No.: 174,579 |
JDM as F*ck. says it all. Love it man |
Nov 7 2009, 05:17 PM
Post
#22
Gripper ![]() ![]() ![]() ![]() ![]() Group: Users Posts: 2,526 Off Topic Posts: 324 Joined: 6-October 02 From: Brisbane Southside Member No.: 296 |
Hot!!!
Nov 7 2009, 05:22 PM
Post
#23
![]() Budding User ![]() ![]() ![]() Group: Users Posts: 613 Off Topic Posts: 18 Joined: 7-March 09 From: Gold Coast Member No.: 162,554 |
Omfg porn Gram lights set this off so well!! |
Nov 7 2009, 05:24 PM
Post
#24
Budding User ![]() ![]() ![]() Group: Users Posts: 1,089 Off Topic Posts: 0 Joined: 13-January 08 From: Brisbane Member No.: 93,372 |
thats the good shit |
Nov 7 2009, 05:33 PM
Post
#25
![]() Resident P Plater Skid King ![]() ![]() ![]() ![]() Group: Users Posts: 1,536 Off Topic Posts: 823 Joined: 8-July 07 From: Brisbane Member No.: 73,492 |
In love
