Welcome Guest
Log In | Register
Start new topic
Wheel Lock Nut,, how the hell do you get em off
mojo_gc
post Nov 7 2009, 03:32 PM
Post #1
Standard User
Group: Users
Off Topic Posts: 0
When i bought my car the front two wheels had lock nuts on them but the back two didnt, and i didnt get a key for the front ones, so i cant get the front ones off.
I have uploaded a pic of the nut, any ideas on how to get it off? without damaging wheel etc..
Cheers
Attached thumbnail(s)
Go to the top of the page
+Quote Post
astro boy
post Nov 7 2009, 03:40 PM
Budding User
Group: Users
Off Topic Posts: 84
hahahaha that sucks mate, tis a shame they are recessed in or you could just use vice grips or sum shit
id just drill into the cnuts, or try to grind a wedge into them
+Quote Post
aufalcon140
post Nov 7 2009, 03:43 PM
aye you!!!
Group: Users
Off Topic Posts: 1,054
go down to a wheel shop, they should be able to help you out
BUY MY SEXY 17" BLACK WHEELS CLICKY CLICKY NOW
QUOTE (micko1212 @ Dec 25 2008, 08:18 PM) *
You know why they call it the xbox 360?
Because when you see it, you'll turn 360 degrees and walk away.
+Quote Post
mojo_gc
post Nov 7 2009, 03:49 PM
Standard User
Group: Users
Off Topic Posts: 0
i went to signature and they could help much there like we could take it off, but its probably gonna wrek ur rim soo mehh, im lost for ideas
+Quote Post
WinKE55
post Nov 7 2009, 04:05 PM
Site Newbie
Group: Users
Off Topic Posts: 0
try and get a socket and smash the socket onto the lock nut, has to be a tight fit. try getting it off that way.
+Quote Post
mojo_gc
post Nov 7 2009, 04:26 PM
Standard User
Group: Users
Off Topic Posts: 0
ill give it a try, i can see this going so wrong but im running out of options.
there isnt a tool like in that shape that would fit in?
my mate has the same shape key for his but its to big, soo devo'd..
pain in the ass
+Quote Post
Rookie ROX
post Nov 7 2009, 04:32 PM
I can read..! And spell..! Rookiepedia
Group: Moderators
Off Topic Posts: 4,584
There'd be no point in lock nuts if you could just buy a normal key would it wink.gif
The best way as suggested is to get a socket that's slightly oversize and hit it on with a hammer. Once you've wedged it in, you should be able to undo it normally. You'll likely ruin the locknut, but there's no purpose of having it without the key.
ROCK ON
R~R
This post has been edited by Rookie ROX: Nov 7 2009, 04:34 PM
Toubl tieping? speeling of consurn? Grama a issshu? punkchu wha? 1300 6555 06!
Idiots who need to call the hotline - low.ryder, evlbt1, ben IS200, wooley (welcome back!), Astra Boi, samrox58, winchymate
Doug the Banstick. Hitting since '95.
'06/'07/'08 Most Helpful Tech Member
+Quote Post
newsky06
post Nov 7 2009, 04:33 PM
Standard User
Group: Users
Off Topic Posts: 0
is it a bmw? if so take it to a bmw service center and they will have a lock nut master set, get them off in 2 seconds.
+Quote Post
MFC05
Regular User
Group: Users
Off Topic Posts: 23
LOL bad luck, i was similar problem but it was an factory wheel lock nut and it was able to get hold one from the manufacture it was an pain as my car had a flat tyre and needed an replacement too when it happend. Good luck mate
+Quote Post
doripig_01
post Nov 7 2009, 04:34 PM
New User
Group: Users
Off Topic Posts: 0
smash some socket onto it, just make sure it isnt one u borrowed from ur dads prized toolbox, or one you may need to use later.. and have a shot at that.. just dont go reefing at the ratchet.. use a long bar and slowly turn it..
+Quote Post
newsky06
post Nov 7 2009, 04:42 PM
Standard User
Group: Users
Off Topic Posts: 0
i just had a good look at those pics, and i am 99% that they are standard BMW lock nuts.
refer to my earlier post^^^^^^.
+Quote Post
r32bro
post Nov 7 2009, 04:43 PM
Site Newbie
Group: Users
Off Topic Posts: 1
if you can, get a big peice of metal shaped like a T and weld to the nut, then just twist off ahaha
+Quote Post
Tweak
post Nov 7 2009, 05:38 PM
Dance Fucker Dance
Contributing Member!
Group Icon
Group: Gold Members
Off Topic Posts: 1,639
OMG so many fucking air head replys in here its giving me a head ache.
Firtsly HOW THE FUCK is it possible "bash a socket ovcer it when the lock nut is RECESSED type
and secondly HOW THE FUCK are you going top be able to " weld a big piced of metal like a T to the nut". MOST MAGS ARE MAD OF MAGNESIUM WHICH MAKES A HOT WHITE FIRE WHICH YOU CAN NOT PUT OUT.
Go to repco and buy a set of allan key socket heads about $12 . GO home and find one thats about 1-2mm too big and tap it in with a hammer. Now slowly with a breaker bar put pressure as if you undoing it increase the pressure graduly until it loosens and comes undone.
If that fails and it strips out then you gonna need a few drill bits 6mm,8mm,10mm then a 12mm and drill the head of the lock nut off get the wheel out and change the studd
+Quote Post
Joey77
post Nov 7 2009, 08:22 PM
Standard User
Group: Users
Off Topic Posts: 0
When I got my Guards rolled they had to get lock nuts of because I did not have the key... They seemed to get it off no problem and they did not even scratch anything SO I suggest just take it someone they prob charge like $10 dollars.....
+Quote Post
Tontseks
post Nov 8 2009, 01:48 AM
Standard User
Group: Users
Off Topic Posts: 0
I had the same problem with my Z32 when I imported it. Came over with 4 locknuts and no key. It was recessed even further in then yours. I tried getting it off using a socket but that didnt work. Even tried using a chisel to cut a wedge into it and turn it, this of course didn't work and because of this the tyre place couldn't get it off. I ended up having to drill through it and destroyed the stud.
Basically take it down to your local tyre shop. They have special sockets with deep groves inside them that they bash on and the groves lock into the locknut then they just turn it. Worked with my rims and mine were alot more recessed then yours.
+Quote Post
Tontseks
post Nov 8 2009, 01:50 AM
Standard User
Group: Users
Off Topic Posts: 0
QUOTE (r32bro @ Nov 7 2009, 04:43 PM) *
Might want to call QFRS ahead of time so they can keep your garage from burning down when the rims catch fire seeing as they're probably made of magnesium and all.
+Quote Post
BuC|<3t-H3@d
post Nov 8 2009, 05:36 PM
Standard User
Group: Users
Off Topic Posts: 0
its simple, use and easy out or a super out!!! same as getting a snaped bolt out of a hole except this actualy has something to grip onto if you had the rite tool as a snaped bolt doesnt, if you can get one of them out you can get this out!
+Quote Post
pugz
post Nov 8 2009, 09:17 PM
Standard User
Group: Users
Off Topic Posts: 3
Hammer and chisel, lock nut removal sockets( very handy ), drill it which would be very easy as once u drill the tapperd there would be no load on the stud it should just screw out easly, even a set of torque bits and hammer a over size one in.. Gl
previous:-93 na silvia-xf falcon ute -93 hilux surf 33' s lifted -vl bomodore -91 camry -L series subaru -89 style side courier -vr bomodore lowed on 19s -17ukn vt wagon 20's slammed interior -300sle merc 87-05 ba futura slammed 20s white walls-mazda 626 wagon-serirra comp ute -88 hilux 2x4
Current: 99 hiace low, 18s motorcross whore
07 kx450f forsale, 09 kx250f fun fun
90 sierra tin top 4x4 fun
88 starlet turbo forsale
+Quote Post
iamhappy46
post Nov 9 2009, 05:02 PM
Senior User
Group: Technical Members
Off Topic Posts: 312
13mm drill bit
Drill through head centre until the head of the bolt is destroyed
Remove wheel frum hub and then use vicegrips to remove left overs which since its not 'clamping' anything onto it will unscrew practically with your fingers.
Amateurs built the Arc, Professionals built Titanic
Smashed VY TT SS ute - :( PICS
Black N14 SSS Pulsar - Freshly rebuilt FWD VQ35 Kelford Spec C Cams, Quartermaster twin plate clutch, 6 speed HLSD manual, 18" Murano Wheels and 350Z front brakes.
PICS
+Quote Post
mojo_gc
post Nov 14 2009, 09:55 AM
Standard User
Group: Users
Off Topic Posts: 0
my mate has the same bmw and he has a key which is the same shape, just too big, does anyone have a key on the coast that i could rent of them? im 90% sure its the standard bmw one..
Im with free to go, racq would they have any luck?
+Quote Post
Reply to this topic Start new topic
