Welcome Guest
Log In | Register
Start new topic
Vt Auto Convert To Manual
brenden_hodges
post Sep 19 2009, 10:49 AM
Post #1
Standard User
Group: Users
Off Topic Posts: 3
im just wondering just bought a manual gearbox and everything else needed to convert from auto to manual so im just wondering how would i go about fitting the new gearbox into my car
[b][u]cars now..
vt commodore s
n13 nissan pulsar for sale $3000
[b][u]previous cars...
vl commodore calais
ford xf panel van (bush basher)
1988 mazda 929 (bush basher)
Go to the top of the page
+Quote Post
NOR011
post Sep 23 2009, 02:21 PM
It's not easy doing what I do.
Contributing Member!
Group: Technical Members
Off Topic Posts: 553
First off make sure you have everything you will need.
You should have:
Gearbox
Shifter
Shifter linkages
tail shaft (series 1 is differnt to series 2 so be carefull)
Shifter surround.
Slave cylinder.
Clutch master cylinder and lines.
Spigot bearing.
Clutch and pressure plate.
Flywheel.
Manual starter motor.
Manual wiring harness.
Shifter surround.
Manual ECU (although it will run with your auto ecu)
Gearbox crossmember and mount.
All the nuts and bolts.
Manual pedal box.
Throw out bearing assy.
Once you are sure you will have everything to complete the job.
Remove your exhaust (from your front engine pipe back, dont remove your exhaust manifolds), tailshaft, convertor bolts, starter motor, bellhousing bolts, gearbox crossmember and drop your auto out. Remember to drain the fluid 1st to save cleaning up the mess.
Replace your auto wiring harness with your manual harness and ECU, fit the spigot bush to the crank, bolt up the flywheel, clutch and pressure plate, fit the maunal pedal box, master cylinder and run the lines to the slave cylinder, fit the manual box and crossmember, shifter linkages, starter motor, tailshaft, exhaust, shifter and surround etc etc...
Bleed up the clutch.
Go do skids.
Im sure ive left some stuff out, its pretty straight foward though, you will work it out as you go. Just remember to line your clutch up when fitting (use electrial tape and a broom handle for backyard bogan'ness), and you have to punch out a dowel or 2 to fit the manual box aswell...
QUOTE (bigjim @ Oct 8 2009, 10:59 PM) *
hay hay hay stop all the name calling hahaha.not all of us have half a brane mate.
+Quote Post
Rancher
post Sep 25 2009, 06:08 PM
JDM hater
Off Topic Posts: 1,001
Wrong section...
QUOTE (micko1212 @ Oct 10 2008, 11:59 PM)
HOLY JESUS I saw a twin turbo VE tonight with the plates TT VE. It was a monster. He pulled up next to me at the lights and I heard it idle and I cried a little bit because I was scared.
PM me if you have a wrecked AUTO SR20DET, or CA18DET S13.
+Quote Post
Reply to this topic Start new topic
> Fast Reply
Bold
Italic
Underline
Insert Image
Emoticons
Wrap in quote tags
Wrap in code tags
 Enable email notification of replies |  Enable Smilies |  Enable Signature
