6th February 2008 - 11:18 PM
Post |
Circuit Spec Tune - $1650 Circuit Spec Tune Zero-1 Coil Overs offer an alternative to Tein Flex, without the price tag! Made in Japan, these coil overs feature: * Steel Construction * Mono tube internal construction (inverted damper on strut type suspension) * 15 levels of damper adjustment * Light weight springs cold formed from 9254 steel * Ride height adjustment via base height adjustment as well as fully adjustable spring platforms * Pillow ball upper mounts with camber adjustment (on strut type vehicles) * Larger piston diameter for strut type front and rear * Powder coated brackets * Rebuildable * 1 year warranty when fitted professionally CST has used its years of experience in various motor sports to produce a kit that provides the ultimate balance between comfort and performance. Developed for drivers seeking an aggressive coilover that can be used daily, and provide all the adjustments needed for circuit use. The Zero-1 damper Kit features the latest technology for all drivers who are seeking performance, and adjustability, while not giving up all ride comfort. We have incorporated separate spring perch height, and shell case length adjustment, which allows the suspension to retain more stroke and allows for more suspension tuning. The Zero-1 damper kit includes pillow ball upper mounts, which increase steering response as well as 16 levels of damping force adjustment to give you the ultimate control over your car. Here is a list of the models catered for by CST... Nissan: * HCR32 * BNR32 * ECR33 * BCNR33 * BNR34 * ER34 * Z32 * S13 * S14 * S14 * A31 * C33 Toyota: * JAZ80 * JZZ30 * JZX110 * JZX100 * JZX90 * SXE10 Mazda: * FD3S * FC3S * SE3P * NA/NB * GG3S Mitsubishi: * CT9A * CP9A Subaru: * GDB * GC8 * BE5 * BH5 Honda: * DC2 * EK9 * EG6 * AP1 * PP1 Suzuki: * EA11R/21R Contents of Coil Over kit: * Adjustable Shock Absorber × 4 * Bump Rubber × 4 * Main Spring × 4 * Hook Spanner × 2 * Some applications include helper springs Dust Cover × 4 * Pillow ball Upper Mount × 4 * Lower Spring Seat × 4 If you want an alternative to the other brands out there, but don't want to sacrifice the quality of a Japanese made product, these will give you what you need. We have used these in some of our own cars and are very happy with the results. After street and track testing so far, we have had no problems. To buy these Coil Overs, feel free to PM us at Race Supplies Sydney, leave us a message here or email us at [email protected] and we will reply ASAP. -------------------- |
RaceSupplies
No, they are not. No Jap Spec Coil Overs are! |
RaceSupplies
QUOTE(Fro-Daddy @ Feb 10 2008, 04:31 PM) [snapback]1281912868[/snapback] What are the spring rates for an S15? How much height adjustability is there? Best possible price posted to QLD 4131? Hey Fro Daddy Spring rates are 8kg front and 6kg rear. Front has a minimum lowering of 15mm and a maximum of 90mm. Rear has a minimum lowering of 10mm and a maximum of 90mm. Price to Brisbane is $1725 delivered. |
RaceSupplies
QUOTE(badvr4 @ Feb 17 2008, 01:54 PM) [snapback]1281936590[/snapback] hey dude.coil overs for a mitsi legnum??can u get'em? CST don't make them for that vehicle, but i am looking for other options for you. I will do my best! |
RaceSupplies
Thank you to everyone who has PM'd about these! |
RaceSupplies
Hey sloutch, |
RaceSupplies
Due to the AUD-YEN rate falling dramatically, we have had to suspend supplying the CST Coil Overs. |
RaceSupplies
https://www.boostcruising.com/forums/index....howtopic=396290 |
